Fusable links??
Mar 25, 2005 | 07:43 AM
Fusable links??
My '92 has fusable links on the "Jump Start block" just behind the battery.
I seem to remember reading that the later C4s don't have them.
Is this true? And, what is used instead?
Tom Piper
Mar 25, 2005 | 12:46 PM
Tom: Sometime during the 90's, the OEM's switched to Breakers - 30, 60, 90 for most circuits if I remenber correctly.
Mar 25, 2005 | 01:34 PM
For 93 and up they added two fuse blocks. (Still has the fuse block on the passenger side end of dash).
Underhood Fuse Block #1 is mounted on the firewall
near the driverside door hinge.
Underhood Fuse Block #2 is mounted on the plastic wheel well in front of the battery.
The only fusible links are two that go to the alternator.
