Interior question
Old Mar 25, 2005 | 01:38 PM
EDMGUY's Avatar
EDMGUY
Default Interior question
Any body know what to use to remove old paint from plastic interior parts.
Old Mar 25, 2005 | 01:43 PM
bogus's Avatar
bogus
someone painted them? they are not factory painted... they are colour molded.
If you need to remove paint, I would try a cloth with laquer thinner.
Old Mar 25, 2005 | 03:47 PM
JCAIRE2's Avatar
JCAIRE2
Laquer thinner will melt the plastic. I don't think there is anything that will remove the paint and leave the plastic unharmed. I'd say your best bet would be to sand the parts down until smooth and level, then repaint with color of choice, or replace them alltogether.
Old Mar 25, 2005 | 04:37 PM
LangstC4's Avatar
LangstC4
If it is light overspray there are home center products that are not as hot as lacquer thinner (Goo Gone, Goof off etc).
Main thing is to test the product before using it. Make sure it doesnt soften or dull the finish. If the plastic piece completely primered and painted, I agree removing the paint would be pretty tough. Easier to find a new or used replacement part, or sand and refinish as recommended before.
Old Mar 25, 2005 | 04:56 PM
EDMGUY's Avatar
EDMGUY
Yes
The left and right sides to the center console. Its not over spray they were red and somebody in the pass got the idea to spray the gloss black.Are these a wash and should I be looking for replacements. Thanks EDMGUY
Old Mar 29, 2005 | 12:38 PM
Mike_88Z51's Avatar
Mike_88Z51
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
They are probably going to have to be replaced. Especially if the painter did it right and sanded them lightly before painting. If that is the case though, you have nothing to lose by trying to remove the paint with a paint stripper before paying for new ones.
I'd try some of the INDOOR paint stripping chemicals available at Home Depot/Lowes first. Ask for the LEAST agressive stripper. Wipe it on a small spot and remove it fairly quickly. After a little practice you should be able to get the time frame to leave it on figured out. I used some orange based paint stripper on interior door frames where I wanted to remove stains without repainting. By putting the stripper on for a very short time before removing it, I was able to remove the stains and brighten the paints apppearence without removing all of the paint.
The indoor paint strippers are generally for water based house paint, but one might work, depending on what your panel was painted with. If not, try the least agressive automotive paint remover with a limited time exposure on the part.
Old Mar 29, 2005 | 12:45 PM
4bblC4's Avatar
4bblC4
https://www.corvetteforum.com/techti...=114&TopicID=2
good article if you manage to get the paint off, and want to repaint.
if the paint is stuck real good on there, I'd say just follow that tech aritcle.
Old Mar 29, 2005 | 09:01 PM
mseven's Avatar
mseven
I have used aproduct by a company named Bulldog it is paint stripper designed for rubber , plastics (of sorts) and polys, This stuff works very well and I have used it to take road paint off of the plastic wheel wells. Spray on small place to test time needed (not that long) wipe off I was wtching preety close so it did not haze or discolor m7
Old Mar 29, 2005 | 10:28 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
I don`t know how good it is, but they sell the stuff at Wal Mart
Old Mar 29, 2005 | 11:50 PM
chb88's Avatar
chb88
I just refinished my center console and I used "After Wash" by Klean Strip Part no AF-91. It worked fantastic at getting the plastic coating off without effecting the base plastic. I then refinished with "Spray Vinyl Dip" that I found at Lowes. It worked wounderful and looks nearly factory perfect. The $5 and 4 hours to strip beats the $150 replacement hands down.
Old Mar 30, 2005 | 07:53 AM
runner140*'s Avatar
runner140*
Default I agree...
I've used GooGone on almost everything, the carpet, the seat belts and anywhere there is a stain and i'm on my second spray bottle.
Old Mar 30, 2005 | 10:18 AM
EDMGUY's Avatar
EDMGUY
Ok Ill look this up at wallmart or the web.Thanks everybody .Will show some pick when I get it completed.EDMGUY
To Interior question
