Really easy dumb question...
Old Mar 29, 2005 | 08:32 PM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
Default Really easy dumb question...
When you bench bleed a master cylinder, do you want to depress the piston all the way so it bottoms out, or will that ruin the seals? I have heard that when you bleed the brakes you should not depress the brake pedal all the way (don't know if this is related or not). I'm going to attempt this next week... just wanna make sure I've got my facts straight...
TIA,
Ed
Old Mar 29, 2005 | 08:52 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
When I did this operation last fall the instructions said to use a few quick short strokes (please...) and then wait for air bubbles to stop.
I found it took a combination of short & long strokes (please...) with some tilting to get the job done.
Don't bottom out the plunger as this is how I got mine stuck and had to replace the MC.
BTW, it took quite a while to bleed the rear of the MC as this portion moves less volume as the front due to the front/back bias.
Old Mar 30, 2005 | 09:16 AM
eschoendorff
St. Jude Donor '08
I have an LT1 car and the MC is a *little* different. Is there any difference in the bleedinmg technique? Can't really imagine that there would be...
Old Mar 30, 2005 | 10:18 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Originally Posted by 65Z01
I found it took a combination of short & long strokes to get the job done.
Hey Jim, let's keep your personal life out of this!!!!
(sorry couldn't resist)
See you Saturday.
To Really easy dumb question...
