Tranny shift question
Old Mar 25, 2005 | 06:11 PM
vettish 91's Avatar
vettish 91
Default Tranny shift question
91 with automatic tranny....when gas pedal is to floor tranny used to shift pretty consistantly at 5500 rpm now shifting is over 6000rpm, is this an easy adjustment or is this the beginning of something bad??? I already tried to reset the tranny cable up by the plenum/throttlebody, Didn't change anything.
Old Mar 25, 2005 | 10:26 PM
Mo_Bandy's Avatar
Mo_Bandy
I've been through two trans rebuilds, my last one I kept "punching through to the rev limiter. Generally, the 2/4 gear is the weakness. I'd suspect 2 nd gear is slipping...
Mo
Old Mar 26, 2005 | 09:53 AM
bobmic93's Avatar
bobmic93
Im in the same boat with you. At WOT I can manually shift into 2nd but 3rd and OD It wont shift at all. WOT in D or OD and the car wont come out of first. But it all works fine at part throttle. Im taking her in this week to be looked at by a pro. Im praying I dont need a rebuild.
Old Mar 26, 2005 | 09:59 AM
Pete K's Avatar
Pete K
Remove and inspect the governor. If you are lucky the gear is bad.
To Tranny shift question
