Help Please....Shift Knob removal
Old Mar 25, 2005 | 07:21 PM
Alcee1's Avatar
Alcee1
Default Help Please....Shift **** removal
Can someone tell me how to remove a manual shift ****, I have the top cover off but there is a square metal piece in there, what to do with that. Thanks in advance...
OOOOPPPPPSSSS sorry for posting this in the wrong section... :bb
Old Mar 25, 2005 | 07:27 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
it is a complete PITA to remove, but try to squirt some wd40 around the base and let it soak for a moment. Then try to grab it with a pair of needle nose pliers and pull like a ****. Also, don't be afraid to use a flat head screw driver to pry on it, but be careful when you do that.
Old Mar 26, 2005 | 10:56 AM
65coop's Avatar
65coop
St. Jude Donor '05
Auto ot standard?
Old Mar 26, 2005 | 11:11 AM
Strick's Avatar
Strick
The best way to get it out is to grab the key with a good set of vice grips and tap it out with a small hammer. I had a small C-clamp that I put on the vicegrips so I could tap on something.
Old Mar 26, 2005 | 01:03 PM
Irishpilot03's Avatar
Irishpilot03
if it is a 6-speed, the best way to get that off is to fabricate a thin, flat piece of metal and put a 90 degree bend a 1/4 inch away from the end. Then it will grab on the lip of the metal peg and it will come out really easy.
Old Mar 26, 2005 | 05:43 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I removed the roof, got some good standard pliers, and stood on the seats and pullled as hard as I could.
If you have anything that can get under the lip of the metal wedge without messing up the leather ****, it helps.
And when you put it back in, just tap it in lightly, save you or someone else the same hassle later on.
Old Mar 26, 2005 | 06:54 PM
bogus's Avatar
bogus
Gee... the automatic is SO easy...
Use a small screw driver and pop off the push button... under that is a snap ring. Remove with the same screwdriver. the **** comes right off.
This is how it works on bastet44's '87. Took 5 minutes.
Old Mar 28, 2005 | 04:06 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
You don't have to make this tool. Go to an autoparts shop and buy a brake tool adjuster. It's the one that turns the self-adjusting cog on drum brakes and it looks like a mini-prybar. It works great on the 6-spd wedge pin.
gp
To Help Please....Shift Knob removal
