Key question
Old Mar 25, 2005 | 08:57 PM
gotn2o?'s Avatar
gotn2o?
Default Key question
I just got a 91, and there's only one set of keys with it. I want to get an extra set, but the ignition key I have has no resistor. There is just a hole in the key where the resistor should be.
Is it possible to get a key made with no resistor?
Old Mar 25, 2005 | 09:10 PM
jabez's Avatar
jabez
Just have a key maker cut one out for you.
Old Mar 25, 2005 | 09:19 PM
gotn2o?'s Avatar
gotn2o?
Thanks. I know it sounds like a really stoopid question, but I was afraid that the only way to get one wouldbe to order one with a resistor (and punch it out).
Old Mar 25, 2005 | 10:40 PM
rws.1's Avatar
rws.1
I do not know it the '91 was a VATS era model or not.
IF it was and your resistor is missing... someone did a VATS bypass.
IF it wasn't or someone did, you don't need to worry about it...
other than a non VATS car has had a key part of the theft deterent system removed and your car is a lot easier to steal
Old Mar 26, 2005 | 01:38 AM
gotn2o?'s Avatar
gotn2o?
It seems that it was a VATS car, since the key has a spot for the reistor. My first step is to get an extra key or two in case we lose this one. My second step is to see if the VATS is bypassed, and see if I want to re-enable it to prevent theft.
I may leave it alone, and get a different theft deterrent.
Thanks.
Old Mar 26, 2005 | 09:42 AM
c4cruiser's Avatar
c4cruiser
The key with the pellet showed up in 86 and continued on thru the end of the C4 run. You can get a VATS Bypass wiring connector that effectively disables the factory VATS system. The keys with the pellets are pricey and you may find that a dealer will require ID and proof of registration to duplicate a VATS key. Lockshops should be able to make a key too. There are 14 different combinations of key based on the resistance value of the pellet.
I think you would be better off to get the correct key and if the VATS system is working, you can disable it by getting the so-called VATS Bypass connector from the various accessory catalogs.
Old Mar 26, 2005 | 02:50 PM
gotn2o?'s Avatar
gotn2o?
I'm thinking that the VATS is already disabled or broken. I can use the key without the pellet and everything seems fine.
Old Mar 26, 2005 | 03:03 PM
Grace91's Avatar
Grace91
I had the same issue with my '91 when I bought it.... one one set of keys.
I had to go to the dealership and show them my title before they would cut me a new pellet embedded key. I think it was about $40.
The problem I think you might run into is that you don't have a pellet. The dealer has a cool little device that they stick your original key into. This device reads the resistance of the pellet which indicates which key they need to seel you. I don't know how you know which key to buy if you don't have a pellet to start with.
Old Mar 26, 2005 | 03:41 PM
gotn2o?'s Avatar
gotn2o?
I agree. That's what makes me reluctant to try to revive the VATS if it's not broken. If the key without the pellet works, and I can duplicate pelletless keys, then I may just go with that concept.
If I keep down that road, I'll need to know what ant-theft devoces other people have used effectively. Any suggestions?
Old Mar 26, 2005 | 04:03 PM
MikeC4's Avatar
MikeC4
The VATS bypass harness is nothing more than a resistor of the same value your car ignition key was originally equipped with. As another member indicated, there are 14 unique pellet keys which are designated by 1-14. The numbers are simply the resistance, so a vats key code of 2 means it is a 2K ohm resistor, a VATS key code of 10 is a 10K ohm resistor. You can easily measure this yourself with a DVM. If you so desire to re-enstate your VATS system, find the location of the VATS bypass harness and measure the resistance across the wires to determine your key code. There is nothing mysterious about the VATS key resistor pellets. Here's a link to Ecklers which shows the 14 different pellet keys, and 14 different VATS bypass harnesses....
Don't spend $40 at a dealer when you can get a blank pellet key for $15 and take to a hardware store and get it cut for a couple of bucks.
just enter ===> vats where it says "Keyword or Eckler Part#"
http://www.ecklers.com/find.asp?mscs...6VX0AWTK293EAC
Old Mar 26, 2005 | 04:42 PM
Steel Blue 91's Avatar
Steel Blue 91
You will have an issue if you find the bypass and remove that resistor. Don't have my manual handy, but the resistance value is stored in (I think) the CCM. It is seeing the bypass as the correct value and allows you to start the car. When you find the by pass, you can get the resistance read at Radio Shack (or do it yourself with a DVM), match it up to the resistor chart (someone posted it a while ago) and get a key with that value cut. That way you will have a fully functional VATS.
OK, so I'm second with the info.....
Old Mar 26, 2005 | 05:08 PM
gotn2o?'s Avatar
gotn2o?
Thanks.
Old Mar 26, 2005 | 05:23 PM
TPFKATK's Avatar
TPFKATK
My 88 was like that when I bought it too. The PO removed the pellet and soldered it into the wires running up the steering column. Take a good look under the dash. If I remember correctly (it's been years) the wires are both yellow and very small gauge.
Harold
Old Mar 26, 2005 | 05:51 PM
gotn2o?'s Avatar
gotn2o?
Thanks. I'm seriously considering leaving it alone.
If I do so, what are some good anti-theft / alarm devices?
The remote is also missing from the car, so an aftermarket solution may be in the future.
Old Mar 26, 2005 | 05:57 PM
TPFKATK's Avatar
TPFKATK
I have an aftermarket alarm on mine. It has remote lock/unlock and rolls the windows up when armed. I love it.
Old Mar 26, 2005 | 06:06 PM
gotn2o?'s Avatar
gotn2o?
What kind?
Old Mar 26, 2005 | 11:49 PM
86 blue vette's Avatar
86 blue vette
Default key
ok i have read post here for like two years i dont post much mostley read em the vats system is a recall item dealer has to fix for free no mater how old your car is they recalled them because the vats system wasent reconizing the keys leaving motorest stranded mine used to do it it would start fine then once in a blue moon it would not start come back 20 min later starts fine go to gm recall or auto zone . com they have recall info at auto zone.com if its a recall and they have not done it yet they will replace vats and cut you new keys also recalled is the brake sensore on top of master cylender it can cause loss of brakes with no warning call dealer tell them you have recalled stuff not yet done they have to fix it it is the law hope this helps
To Key question
Old Mar 27, 2005 | 11:06 AM
gotn2o?'s Avatar
gotn2o?
Thanks. I'll take it over and see what happens.
Old Mar 27, 2005 | 12:00 PM
jabez's Avatar
jabez
40 bucks? Another dealer ripoff. When I wanted a spare key I took it to a mall kiosk and they measured and cut my key for 22.00. Didn't even need to show any ID.
Old Mar 27, 2005 | 02:23 PM
gotn2o?'s Avatar
gotn2o?
Went to Lowes and had them cut a door and ignition key both. They screwed up the ignition key match, it won't turn. I'll have to get them to try again.
Checked the recall info from the NHTSA. No VATS recall for a 91.
I may look to see if it's bypassed, but I think I'm gonna leave it alone, get a couple of extra keys, and look for a decent aftermarket security system.
