Donuts anyone?
Old Mar 26, 2005 | 07:09 PM
brogden31's Avatar
brogden31
Default Donuts anyone?
I have a 85 i think it runs very well , but if i get on it hard around a corner or doing donuts it will stall and ill have to cut it off and restart it and it will be fine again i usually have about 1/4 tank gas im thinking the factory fuel pump sucks from the bottom of the tank and the gas is moveing to the side couseing this problem.
Old Mar 26, 2005 | 07:17 PM
Metamando's Avatar
Metamando
Exactly!........Autoxers have known this for years, and never run without a full tank. Also, in a car that old, you may have a buncha sediment in the tank.
Old Mar 26, 2005 | 07:37 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
C4 trade mark Minimum 1/2 tank rule is in effect
Old Mar 26, 2005 | 07:49 PM
smack123's Avatar
smack123
Hey brogden31..
Thanks for asking that question - I have had that happen twice to me while pulling a U-turn or somewthing and wondered what the deal was... usually low on gas a the time.
Now I know...
Old Mar 26, 2005 | 08:55 PM
rightofway's Avatar
rightofway
i noticed this over a speed bump with less than 1/4 of a tank.
also i noticed i seem to get better traction with a full tank.
just my $0.02
Old Mar 26, 2005 | 09:12 PM
Metamando's Avatar
Metamando
Realise a C4 has almost NO weight on the *** end (that's why they're so easy to turn around), so a full tank o' gas will help you in every way. More traction, less wheel spin, better cornering, and no fuel starvation!
You young guys, I realise gas is expensive, just fill up once, set the trip odom, and fill up every time it says 100 or 150, that way you only buy half a tank at a time. I have to do this.......my fuel gage is broke, hehe!
Old Mar 26, 2005 | 09:39 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
When I first got my car, I drove it home from Arkansas (I live in St. Louis). When I got home I took my wife and friend for a ride and when I stomped the pedal to the floor it stalled bad. I thought I had just bought a lemon, but it was just low in gas.
Old Mar 26, 2005 | 10:13 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
If the pump isn't submerged, it runs hotter, plus sucking air will wear it out faster.
Could very well be that your pump is on it way out too, that will exaggerate the problem.
Old Mar 27, 2005 | 03:46 AM
brogden31's Avatar
brogden31
Thanks For The Input Everyone!
Old Mar 27, 2005 | 04:05 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
You have an 85 .The gas tank keeps 41/2 gallons to 3 gallons you can never use and that burns up the pump when low on fuel.
To Donuts anyone?
