ZF fluid change question.
Old Mar 26, 2005 | 07:51 PM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
Default ZF fluid change question.
Where in the world did you find a 17mm hex? Biggest I've been able to find is 10mm.
Old Mar 26, 2005 | 07:54 PM
Metamando's Avatar
Metamando
I would try Sears, GMParts Direct, or a local Snap- On dist.
Old Mar 26, 2005 | 08:07 PM
LT-4 CE's Avatar
LT-4 CE
Struck out at Sears and Lowes. Haven't checked the others. Thanks.
EDIT: just saw it on Sears web site. Need to hit a bigger store.
Old Mar 26, 2005 | 08:14 PM
Metamando's Avatar
Metamando
Craftsman Rules
Old Mar 26, 2005 | 09:31 PM
MYCoupe's Avatar
MYCoupe
If you can wait a few days for it check eBay. I had a hard time finding it as well at the local stores. Got a Snap-On one on eBay at a really nice price and it was like new.
Old Mar 26, 2005 | 11:15 PM
TrackDayLT4's Avatar
TrackDayLT4
I got mine at Autozone.
Cheers,
Lawrence
Old Mar 26, 2005 | 11:18 PM
tempest's Avatar
tempest
same here. it was part of a three-pack of big hex sockets. i would usually not buy tools there, but for something i will use only once a year, i made the exception.
Old Mar 27, 2005 | 09:30 AM
96CERon's Avatar
96CERon
Auto Zone--3 pak
Old Mar 27, 2005 | 10:07 AM
LT-4 CE's Avatar
LT-4 CE
Looks like a trip to Auto Zone first. There's one closer than a Sears.
Old Mar 27, 2005 | 11:43 AM
cresus's Avatar
cresus
Autozone has a set of 3 for $8 that has it in there. Just bought it the other day.
Old Mar 27, 2005 | 12:20 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
Autozone here, or some have used a 17mm bolt with a nut fully tightened on it, in effect turns the hex into a socket.
Old Mar 27, 2005 | 12:37 PM
TravisD's Avatar
TravisD
I'm pretty sure I've seen it at Sears. I think mine came from some random autoparts store -- I originally bought it for my '74 VW! I like the big allen key since I can put a 17mm wrench on it for more torque.
Make sure you loosen the fill plug first -- nothing like draining the lube and then realizing that you can't refill it.
Old Mar 27, 2005 | 03:23 PM
bogus's Avatar
bogus
Mine came from either Autozone or Advance Auto...
Old Mar 27, 2005 | 05:47 PM
jrscott's Avatar
jrscott
Not to step on the conversation but it's a good idea to check the fill plug first (Travis ) and then the drain. Everyone talks about how hard they are to get out, just run the car a few miles and warm it up; they will come out REAL NICE!!!!!
Old Mar 27, 2005 | 10:35 PM
Photomania's Avatar
Photomania
Default Get ready to wrestle with that plug
I tried using a 17 mm Allen wrench and a 17mm hex socket on my breaker bar, and accomplished nothing. Hopefully, you'll have better luck. Someone mentioned driving the car to warm up the transmission. I wish I had done that. I took my 1990 six-speed Corvette to a Corvette specialty shop, and they got the plug off, but only after applying heat. They changed the transmission oil. On the advice of someone on this forum, I had purchased two plugs to replace the old ones. That was a good idea, because the old plugs were in bad shape. By getting the shop to do the work, I had to pay $80 or $90. -- Eric
To ZF fluid change question.
