Drive shaft loop and Half shaft loops installed
Old Mar 27, 2005 | 03:50 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Default Drive shaft loop and Half shaft loops installed
What a job to install the drive shaft loop.
Looks easy here
http://zfdoc.com/c4SafetyLoop.htm.
Installed the new verson of the half shaft hoops work great.
http://www.dragvette.com/
I don't recomend the drive shaft loop for the faint of hart.
Half shaft loops easy.
Now I will see if the car will do 10's in the 1/4.
A corvette I don't think so ,and stay together
Old Mar 27, 2005 | 04:06 AM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
Cool loops John, Pretty interesting.
Did you see Mojos post in general with the video of the C5r VS. the C4 with a ton of nitrous. The C4 ran 8.8 @ 159 mph and stayed together. Check it out..
Originally Posted by Mr Mojo
Please right click,save as. 4 meg file. Thanks to the Vette Doctors for hosting.
http://www.thevettedoctors.com/corve...6-26-2004s.wmv
Old Mar 27, 2005 | 06:02 AM
REDC4CORVETTE
The only thing about nitrous is, you brake more parts than turbo or supercharged cars .
Old Mar 27, 2005 | 01:56 PM
scorp508's Avatar
scorp508
Until you send an impellar blade down into the intake.
Are the C4 halfshaft loops on that page anywhere?
Old Mar 27, 2005 | 03:03 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Those are solid axle car not IRS
Old Mar 27, 2005 | 03:28 PM
Nathan Plemons's Avatar
Nathan Plemons
Those half shaft loops look pretty straightforward. Do they require any modifications or do they just bolt in? If they just bolt in I seriously need to invest in a set.
Old Mar 27, 2005 | 03:43 PM
Mad-Mic's Avatar
Mad-Mic
thats why you invest 500 bucks or so for a programmable nitrous controller like this one.
This top-of-the-line unit can be programmed to control both the amount of nitrous that is flowed to the engine (from 0-100%) and the time desired to ''ramp up'' from first hit to full flow. For example, you can program the controller to flow 25% of the nitrous 1.5 seconds into the run and increase to 75% at 5.3 seconds. Or it can go all the way to 100% much sooner. This enable a racer to fine tune the power curve of an engine to best utilize prevailing conditions. One of the most sophisticated progressive nitrous controllers on the market yet, very easy to use, each function is set through simply turning a series of dials to the desired position and pushing a ''program'' button.
http://www.jegs.com/cgi-bin/ncommerc...76&prmenbr=361
they range from 300+ to 500+
back on subject! how long did it take to install the said components and any hangups?
Old Mar 27, 2005 | 03:52 PM
CFI-EFI's Avatar
CFI-EFI
They certainly know how set prices for Corvette owners. That $179.00 drive shaft loop is 1/2 of a $25.00 "universal kit" you can order from Summit. What caused all the trauma installing the loop?
RACE ON!!!
Old Mar 27, 2005 | 04:35 PM
AS84's Avatar
AS84
those controllers are very hard on solenoids. We tried one and found that we were rebuilding solenoids every 5 passes on a 400 shot. Now we run 2 stages on a timed delay. Much easier on some of the parts.
To Drive shaft loop and Half shaft loops installed
