To all who have Converter experience
Thanks!
Thanks!
:So thats my .02 There are few C5 Guys running some higher stalls 3000 and up.
-=Rick
I just am hoping it will act normally moderate acceleration.....
You dont want the stall to happen at the torque peak, you want it lower.
vader, do you think it will actually stall at 3200?
A lower stall will keep you in the fat part of the torque curve longer. Different answer if you raise the power curve too by changing cams and induction.
I would personally go no higher than 2400 on a car I drive every day, maybe 2600 for a drag car.
At least with Vigilante you can have the converter stall changed once for free, unless they changed that.
It also would depend on converter brand, some will be more efficent below the stall speed and thus feel firmer then others.
I really like my 2700, below about 40mph at low throttle input it definately feels loose, but you get use to it.
remember a 3200 stall will not stall out that far if you are BRAKE stalling the car. it will most likely stall to about 2600-2800 depending on torque outputs and we all know L98's make alot of torque.
now if you FLASH stall the car it WILL hit at 3200 rpm.
as for drivability you'll lose alittle gas milage and she won't be a dyno queen cause high stalls eat up HP due to the "Looseness" of the stall converter.
if you want i can give you a number to a friend that builds stall converters and knows his stuff. you won't get a "Clone" stall converter. with his you can actually tell him "How" you want it to perform. want it to hit hard on the launch or come in easy? there is alot he can do to the stall to get what you want with a custom build not like what you buy from jegs or summit again these are clones and massed produced.
ask for Chris and tell him Mad-Mic with the loud @ss red C4 vette from FBC sent ya
http://www.ccmconverters.com/
he will be restalling my 2600 stall that i had sitting for awhile and i will be putting it in very soon
ging with a 3200 stall but with a LT1 intake/ZZ409 cam/388 stroker/with a 150 shotand if your skeptical of his verters goto http://www.easternfbody.com and ask around. that is one of my car clubs i'm in and they are the worlds largest 4th Gen FBody club in the world
RACE ON!!!
[EDIT]"It certainly is too much." Should read, "It certainly ISN'T too much. Sorry, all.
Your best bet is to call the torque converter company and give them your specs and plans for driving and they will help you pick a stall.
The hard thing about C-4's is they are so well balanced from the factory, we cannot make just a mod or two and improve much. But, YES, once you sink the needle in, it is hard to stop!
