Clutch Going Out, Please help!
Old Mar 31, 2005 | 08:22 AM
cresus's Avatar
cresus
Originally Posted by pwoolford
cresus, which clutch did you use? I got under mine yesterday and it doesn't look too bad. I may as well put in the hurst shifter while I'm at it.
I used a sachs clutch (OE style) since I haven't done anything else to my car. Only thing I recommend is having some trans oil there before you're putting it back together as that's what I'm waiting for since no one around here has the stuff I need. (I ordered some Redline MTL as it's my only real option and recommended as an alternative by Bill at ZFDoc). I may still try and order some Castrol TWS depending on if I can find some quickly.
