Supporting rods w/EM Headers
Old Mar 27, 2005 | 06:07 PM
dan6712cc's Avatar
dan6712cc
Default Supporting rods w/EM Headers
How did you guys get the supporting rods that mount up to the driver side manifold bolts to hook up with the bolts suplied by EM. They look like theyre not long enough.... did anyone else run into this problem?
Old Mar 27, 2005 | 11:36 PM
tjwong's Avatar
tjwong
You have to omit one of them. And the other you grind off some material on the end to clear the tube. Then it will mount onto the stud without any problems.
Old Mar 28, 2005 | 12:00 AM
Dan Parker '96's Avatar
Dan Parker '96
I gotta jump in with another question concerning the EM longtubes.
Is there anything special needed to get the A/C compressor struts to bolt up properly (this is on a '96)? My EMs are on the way and would like to be prepared.
Old Mar 28, 2005 | 01:46 AM
tjwong's Avatar
tjwong
Originally on your LTx engine. On the drivers side third bolt from the front on the headers. There are two struts coming from the Alternator and one from the back of the AC bracket. One of them has to be omitted and I think its the alternator strut. If I have time tomorrow morning before I go to my shop I will get a digital picture of my car. Then I can post it so you can know how it should look. At that third bolt location you have to use the factory stud and use a spacer that should have been part of the headers. Using the stud you can place one of the struts to that point. The other has to be omitted.
Old Mar 28, 2005 | 01:48 AM
StealDads67's Avatar
StealDads67
Couldnt have said it better
Old Mar 30, 2005 | 10:19 PM
Dan Parker '96
Thanks tj,
I figured a spacer would be needed. I hate eliminating supports the factory figured were necessary. Hopefully nobody has anything negative to report from the deletion.
Old Mar 31, 2005 | 12:25 AM
MarkBychowski's Avatar
MarkBychowski
I left all three brackets off when I installed my EM's last year. I noticed that with the AC on, it now has a nasty vibration in the 2000-3000 range. I'm going to add the AC brace and one alternator brace back which will hopefully take care of it.
My engine also does have a very minor balance problem, so it could just be that it's being magnified. If your engine is in perfect balance, you may not have the same problem I am.
Old Mar 31, 2005 | 12:52 AM
Dan Parker '96
Mark,
Thanks for the response. I'm definitely going to try to come up with an alternative to keep the full bracing.
You'd think that spending a grand for headers and the necessary accessories would eliminate the need for "shade tree" engineering.
Nothing against EM (they deliver a terrific product). But a true "bolt on" installation would be nice. Just another weekend dotting the "I"s.
Hopefully some manufacturer is listening.
Old Mar 31, 2005 | 04:07 PM
MarkBychowski
Yea, I'm with you. The SLP stainless shorty's I used to have had the spacers built in on both sides (dipstick mount on passenter side). They were actually very nice quality -- just didn't add any power
To Supporting rods w/EM Headers
