My low coolant temp. issue solved.
Old Mar 27, 2005 | 07:44 PM
Aardwolf's Avatar
Aardwolf
Default My low coolant temp. issue solved.
Thought I would share. When I got the car idle temps would be fine (210-233) when warmed up, driving the car would cause the temp to fall way low. 150-160 degrees. I got a new thermostat figuring that was the problem, and it was. Installed a new 195 over the weekend, now the car stays at 193-197 while driving. problem solved! Ahh nice to have some heat again! Also gas mileage is MUCH improved. I think it was the orignal thermostat, perhaps the spring was weak, or? All new coolant to. I put in the balanced type thermostat.
http://store.summitracing.com/defaul...0&autoview=sku
Url there if your curious. I was sooo relieved that drain on the radiator opened ok!
