header Question
Old Mar 28, 2005 | 12:00 AM
wildbilljr's Avatar
wildbilljr
Default header Question
When installing header with no emissions and no cats and only flowmasters.. what do you have to do with ECM or any thing else in an 88 .. air pump going to
thank you
wbj
Old Mar 28, 2005 | 01:57 PM
lallend's Avatar
lallend
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13
Pretty much nothing.
My 87 is like what you described, but with Corsa's instead of Flowmasters and it runs fine. One thing though, I am using a heated O2 sensor instead of the stocker.
Your car should run fine (like mine does now) but having a tuner fine tune a chip would probably be nicer to get a few more HP etc.
Heh, you will notice a nice sotp change even without burning a custom chip
Old Mar 28, 2005 | 02:28 PM
tpi1986's Avatar
tpi1986
Long tube headers will make the motor "wake up". Just wait until you get your LT1 intake on there and then get your chip.
Old Mar 29, 2005 | 11:32 AM
wildbilljr's Avatar
wildbilljr
hey TPI 1986
how are you ??? thank you for the in put and did you need any thing from korea ?? and i cant wait to get home im going to sleep in my car the secound night because the frist night you know have too have some alone time with the wifey
later bro
wbj
hey whats the deal with the 135.00 $$ headers from summit??
Old Mar 29, 2005 | 07:20 PM
pipe's Avatar
pipe
Hey Wild Bill I put Hooker long tubes on my 90 coupe with the Y Pipe then branched it off into 2.5 inch pipes going back to Flowmasters without a cat convertor. Also I have no smog pump on the car either. When I hooked up the code scanner to the car it showed absolutely no codes thrown after these changes. GOOD LUCK Pipe
Old Mar 29, 2005 | 08:42 PM
Chris 96 WS6's Avatar
Chris 96 WS6
The heated o2 sensor is a good recommendation. The headers move the sensor further downstream and it will take longer to get the sensor up to operating temp and you'll have less reliable readings in closed loop.
To header Question
