GM 847 cam
Old Mar 28, 2005 | 11:45 PM
pr0zac's Avatar
pr0zac
Default GM 847 cam
anyone running one? how do you like it? what other mods do you have? was it hard to tune?? rwhp? thanks
Old Mar 29, 2005 | 12:05 AM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
I have it in my 396. It's way more cam than you need with a 350. Not the easiest to tune and I strongly doubt you could come close to passing an emisions test. 847 specs
Old Mar 29, 2005 | 12:07 AM
tjwong's Avatar
tjwong
[QUOTE=Ramrod92]I have it in my 396. It's way more cam than you need with a 350. Not the easiest to tune and I strongly doubt you could come close to passing an emisions test. 847 specs [/QUOTE
It sure sounds nice thumping away. And once tune it makes BIG power in the upper RPMs. Ramrod, how is Jeb coming along with your DFI installation?
Old Mar 29, 2005 | 12:11 AM
pr0zac's Avatar
pr0zac
it would be going in a 383 with afr 210's
Old Mar 29, 2005 | 12:22 AM
tjwong's Avatar
tjwong
It would be a good cam choice for that. I have a friend that has a MTI built 396 using a 847. It made around 550hp on their dyno. They used ported LT4 heads if I remember right and running 11:1 compression.
Old Mar 29, 2005 | 12:27 AM
Ramrod92's Avatar
Ramrod92
Tom, Jeb had PRK work on his eyes and is slowly recovering. Sounds like his eyesight was as bad as mine (20/800). You online on a different computer, can't IM you?
Old Mar 29, 2005 | 08:20 AM
pr0zac's Avatar
pr0zac
it is going to be 10.5:1 and i am going to use a converted LT1 manifold and porting the hell out of it. got my holley commander 950 last week. all i need is injectors.
Old Mar 29, 2005 | 07:03 PM
crheinish's Avatar
crheinish
good choice, that cam on stock heads makes 360 to the wheels.
To GM 847 cam
