tps voltage
Old Mar 29, 2005 | 10:11 PM
rlane5's Avatar
rlane5
Default tps voltage
Hi guys,
How much voltage should a TPS have at closed and full throttle?
Randy,
Old Mar 29, 2005 | 10:25 PM
jfb's Avatar
jfb
Throttle closed, tps voltage must be .54 v +/- .08 volts. Throttle open should be over 4.0 volts.
Old Mar 29, 2005 | 10:44 PM
sniperdiver37's Avatar
sniperdiver37
closed should be under .5 volts. around .48-.46 is good.
as you open the throttle you should look for smooth increase to 5 volts wide open full throttle. any flat spots is a bad TPS.
this test is done w/ the motor off, key on.
loosen the top screw of the TPS to adjust. Good luck~ Jeff
Old Mar 29, 2005 | 10:49 PM
scorp508's Avatar
scorp508
You don't have (and shouldn't expect) to get a full 5 volts at idle. Its damn near impossible to get that and the proper idle voltage. Anything over 4 is fine.
Old Mar 29, 2005 | 10:56 PM
rlane5's Avatar
rlane5
Thank you for the info, I will try to adjust it tommorow, I want to take it to E-town saturday for the corvette challenge.
Randy,
Old Mar 30, 2005 | 09:32 AM
Lone Ranger's Avatar
Lone Ranger
I would just add that this question also depends on engine type. Above info is for L98. LT1 and LT4, PCM will interpret as little as 3.75v as 100% TPS.
Old Mar 30, 2005 | 09:42 AM
scorp508's Avatar
scorp508
A stock L98 will do the same, but is not self-adjusting like an LT1/4 is. The base ECM program assumes anything over 69% throttle is full throttle and puts the car into Power Enrichment mode.
5.00 volts * 0.69 = 3.45 volts
To tps voltage
