Takes a long time for engine to start
Old Mar 30, 2005 | 01:09 PM
saniterium's Avatar
saniterium
Default Takes a long time for engine to start
Lately my '92 has been taking a long time start after I turn the key. The engine starts first try, every time, but usually it takes like 4-5 seconds for the engine to turn over. Any suggestions on what the problem might be and what needs to be done would be great.
Old Mar 30, 2005 | 01:14 PM
Chris 96 WS6's Avatar
Chris 96 WS6
Well its either two things:
1. Fuel
2. Ignition
Does the pump prime when you turn the key? Wonder how your fuel pressure is looking? If you have a lazy pump or if you have a leak somewhere (e.g. a leaking injector) then it can extend start time.
In terms of the ignition, how old are all the major components? Opti? Wires, plugs, coil, module?
Old Mar 30, 2005 | 01:17 PM
saniterium's Avatar
saniterium
Im pretty sure everything you listed, other than (I HOPE!) the spark plugs are original. I just got the Vette a couple of weeks ago so I'm not exactly sure what been replaced recently on it ignition wise.
Old Mar 30, 2005 | 01:48 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Turn your key on and remove the vacuum line from the Fuel pressure regulator and see if any gas is there. That means it is bad and was what was causeing my hard start problem it was dumping gas into the intake. Does it idle right on startup or runs a little rough for a few secs?
Old Mar 30, 2005 | 02:07 PM
CFI-EFI's Avatar
CFI-EFI
Is it any worse, hot or cold? The two prime suspects are leaking injectors or a fuel pump relay.
RACE ON!!!
Old Mar 30, 2005 | 05:54 PM
saniterium's Avatar
saniterium
It usually idles perfectly when it finally does start up. Occasionally the idleing will kind of "lag" for one sec when started, and then the engine roars back up to where it should be. Also, no it is not any worse in hot or cold weather.
Old Mar 30, 2005 | 06:11 PM
Redeasysport
Does it start right after sitting overnight or ever? Does it always start poorly?AS CFI-EFI said it could be the pump relay. Put a guage on the rail and turn the key on it should kick in the relay and pressure up the rail. If you don't have around 40psi at that time the relay did not start.The pump WILL kick in when turning the engine over due to oil pressure turning the pump on. It will delay the startup till enough pressure is developed. Do both checks I have given you.I thought mine was an injector issue and wasted a lot of money only to find the pressure regulator was bad.
Old Mar 30, 2005 | 06:26 PM
saniterium's Avatar
saniterium
Some times it will start right up after an overnight sit, but usually not. However it always starts right up if say I just turned the engine back off, and try to start it again.
Old Mar 30, 2005 | 08:19 PM
Shore's Avatar
Shore
You got some leaky injectors..My 92 did the same thing.I had two that were seeping pressure.I replaced them all with some known good ones and never happened again.
Old Mar 30, 2005 | 08:28 PM
notherc4's Avatar
notherc4
My 94 does the same thing. First start of the day or after a 12 hour work shift. it has a long start. My Tech said the pump might be lagging. But havent had time to pursue it.
Old Mar 30, 2005 | 08:35 PM
CFI-EFI's Avatar
CFI-EFI
Then is probably NOT the fuel pump relay. As Redeasysport explained, if you have to wait for oil pressure to start the pump, that usually takes longer with a hot engine and it's thinner oil.
RACE ON!!!
Old Mar 31, 2005 | 04:31 PM
Redeasysport
Mine did that it was the pressure regulator pull that vacuum line off and report back.
Old Apr 1, 2005 | 08:37 AM
bmann08's Avatar
bmann08
Cruising
I'm going to keep an eye on this thread. My 91 does the same thing. It takes a while to start when it is cold, but starts fine after it is warmed up. It runs great, so I can't decide whether or not to mess with the ignition or injectors.
Old Apr 1, 2005 | 08:40 AM
bmann08's Avatar
bmann08
Cruising
Sorry about the double posts, but I have a question. Is it bad on the starter or anything else to crank it for 4 to 5 seconds? Should I crank it for a couple of seconds, let off, and go at it again?
Thanks for your input.
Old Apr 1, 2005 | 10:35 AM
seering's Avatar
seering
have a very similar problem, got the same advise.
Found i had a number of little things so far.
I know i have a bad fuel pump, some very suspect injectors, and fuel in the pressure reg vacuum line.
I replaced the pump due to cornering problems.
Already had some 26# injectors on the way (now replaced)
finally got the right pressure reg on it ... (my 96 LT1 has the LT4 mounting bracket).
Thought i had it all fixed .. had no problems 1st few times it fired right up.
Then it took about 5-10 seconds to crank the other day
Next stop replacing what looks like all original plug wires and all new plugs.
Ill let you know if i find something else that might prove helpful
Old Apr 1, 2005 | 10:53 AM
sniperdiver37's Avatar
sniperdiver37
I have an 88 and what I am seeing is that if the out side temps are in the 50's and high humidity I have this same problem. I was thinking it was that dead space between the cold start FI and it being warm enough that it's not needed. Something to think about.
Old Apr 1, 2005 | 01:00 PM
VAHROOM's Avatar
VAHROOM
I had this same problem on my 89 GMC Jimmy. Mine was caused by a leaky TBI injector O-ring. It did the same EXACT thing. The way I found out, after determining there was a pressure drop was when the car was cold, jumpered the FP relay. I let the pump run for 10 seconds or so untill I got back in the car. It started in half a second even when cold. Then the search for the pressure leak began. Found signs of seapage and took care of the issue. Look for leaky injectors, pressure regulator, and pump.
Best of luck.
To Takes a long time for engine to start
Old Apr 1, 2005 | 01:14 PM
VQT88Vette's Avatar
VQT88Vette
RACE ON!!!
Does 92 has cold start valve?
Old Apr 1, 2005 | 01:19 PM
VQT88Vette's Avatar
VQT88Vette
I believed that the cold start valve (injector) work below 100 degree from the coolant reading. When the engine is cold, coolant temp. below 100, the cold start valve doesn't work.
When I had the injectors leaks (hard to start when hot), the car started right up when the engine is cold (any time the coolant temp. was below 100). Above 100, it took forever to started.
Old Apr 1, 2005 | 01:22 PM
VQT88Vette's Avatar
VQT88Vette
stop cranking after 15 sec. to let the starter to cool down.
