ZZ4 Engine Build [PICS!]
Old Mar 31, 2005 | 03:20 PM
NUckINg FuTS's Avatar
NUckINg FuTS
Default ZZ4 Engine Build [PICS!]
After going through two different displacement engines (383 and 408) in the vette, I've decided to return to the good ole' stock 350 (although this engine will be far from stock). The base I'll be working off of will be the popular and much reliable ZZ4 shortblock. As you all know the ZZ4 is equipped with a steel forged crankshaft, GM forged "pink" rods, and LT-1 hypereutectic flat top pistons.
First on the agenda was installing the camshaft. I chose to go with the tried and true Lingenfelter 219 roller cam. The install was pretty straight foward. I bought (3) 6inch 5/16 bolts and threaded them on the front of the cam for extra support. Then from there, I applied Redline assembley lube to the first two journals nand 8 lobes. I carfulley slid the cam and rotated it each time it sat on a new bearing to make sure it wasn't binding. The final step was to install the camshaft retainer plate and torque the bolts down to 10 ft/lbs. (sorry for the cruddy pic)
Next step was to install the timing gear set. I went with a Cloyes dual billet 9-way adjustable timing set. For the lower sprocket, I greased the crank snout with antiseize and used a brass pipe to gently hammer it on. Next, I rotated the engine to make sure #1 piston was at TDC. I gave the timing chain a bath in engine oil then installed it on the upper gear. I then applied assemble lube to the back side of the upper gear, lined up the timing marker on both gears and installed the chain then used the 3 retaining bolt and torqued them down to 20 ft/lbs.
Last job of the day was installing the timing cover. I went all out and bought the Comp Cams two-piece billet cover (sweet!). You'll also notice the trick billet CSI fuel pump block off plate
Next project will be the oil pump and pickup and a hamburgers L98 oil pan. Stay tuned....
Update #2
Old Mar 31, 2005 | 03:24 PM
FoolCrzy's Avatar
FoolCrzy
looks nice. I built an enging from a ZZ4 short block, one time.
Old Mar 31, 2005 | 03:26 PM
FoolCrzy's Avatar
FoolCrzy
looks nice. I built an engine from a ZZ4 short block, one time.
Old Mar 31, 2005 | 03:30 PM
dock351's Avatar
dock351
St. Jude Donor '06
Very nice pics. I'm doing pretty much the same building a 383.
Does your engine use hydraulic rollers?
Im using the cloyes double roller and the same fuel block off plate. looks great!
I'm looking forward to your next post
Old Mar 31, 2005 | 04:17 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Looks great! Did you degree the cam in?Or did you run it straight up or etc?I was just curious how you did it.Hope the new combo works out great for ya.
Old Mar 31, 2005 | 04:20 PM
NUckINg FuTS
Yes, I installed the cam straight up. I'm not to sure on the procedure for degreeing a cam and I'm afraid if I try it I will screw something up. It's best to do it along side someone that has experience in doing this.
Old Mar 31, 2005 | 04:27 PM
cv67's Avatar
cv67
St. Jude Donor '05
Just out of curiosity, why did you go back to the 350?
Old Mar 31, 2005 | 06:44 PM
NUckINg FuTS
For simplicity, driveability, gas mileage, for ease of tuning, and the list goes on. I have not had great success with my previous bigger displacement engines.
Old Mar 31, 2005 | 08:19 PM
KAZ2's Avatar
KAZ2
I think the pics are great, it looks like a "clean room" operation. I think you are having fun, and, the result will be a strong reliable engine. Looking forward to your updates. I would love to pick up a late model truck 4bolt block and start the process. Bogus and others that I respect have said that R&R the engine is the toughest part and I hope that you will document your progress so we can better understand what is a challenge and how it was overcome/tricks. Regards
Old Mar 31, 2005 | 09:55 PM
Hole-Shot's Avatar
Hole-Shot
Looks good!
Keep the updates coming
Old Mar 31, 2005 | 10:42 PM
88BlackZ-51's Avatar
88BlackZ-51
things look good! she will be a strong running 350.
Old Apr 1, 2005 | 12:54 AM
Gar's Avatar
Gar
Nice! Way to clean garage! More pix please...when ya get time.
Old Apr 1, 2005 | 01:41 AM
USAsOnlyWay's Avatar
USAsOnlyWay
I have his old 383, we'll see how it goes later this summer...
Old Apr 1, 2005 | 03:48 PM
jp2002ls1's Avatar
jp2002ls1
Sounds like a familiar build. My current motor is based off of a ZZ4 shortblock, I love it so far, it revs to 7000 rpm and no problems yet. I am still debating whether the pistons can handle 100 shot of nitrous. Good luck and have fun.
Old Apr 1, 2005 | 04:28 PM
JCAIRE2's Avatar
JCAIRE2
I wouldn't risk it if they are the hypereutectic pistons. One good dose of detonation and you'll have a crankcase full of rocks.
Old Apr 1, 2005 | 06:17 PM
cal camara's Avatar
cal camara
Default zz4 what induction are you using?
Are you injecting the beast
cal
Old Apr 1, 2005 | 07:51 PM
NUckINg FuTS
cal
If by injecting you mean fuel, then yes. Nitrous, probably not. A superram will be going on top of the ZZ4.
To ZZ4 Engine Build [PICS!]
Old Apr 1, 2005 | 09:37 PM
Inlove's Avatar
Inlove
Default Ecm?
As you're a pro with engine swaps, how do you plan on "tuning" your chip. I ask as I want to put a mostly stock ZZ4 in my '89 but don't know of a place locally, Hawaii, that can tune my chip while it's in the car. As ZZ4 conversions are not so rare does anyone sell a pre-programed chip that would work.
Thanks for letting me pick your brain.
Old Apr 1, 2005 | 11:16 PM
corvette1990's Avatar
corvette1990
I put a ZZ4 in mine 3 yerars ago and it has been running just fine, despite some other peoples horror stories. I wish I had put the 219 cam in before the install. But it runs fine with the stock cam. I had Fomato chips build me a custom chip over the internet and a phone call and a fax. I ran 12.9 secs in quarter mile again tonight. I guess I will need another chip done when I swap my OE motor back in. Lookin forward to more pictures of project. My machine shop would not 383 stroke my vette motor, he said the walls are too thin and he didnt want to chance it. So I will be happy with a 355, later. Keep the pics coming...did I say that already.;..
Old Apr 5, 2005 | 12:55 PM
cal camara's Avatar
cal camara
Default using stock L98 injection with ZZ4
Can I use the stock 1988 or 89 TPI with a new ZZ4,
cal
