Hose melted
Old Mar 31, 2005 | 07:17 PM
nolan1123's Avatar
nolan1123
Default Hose melted
Hi there I was wondering if anybody can tell me the name of this hose and the best way to repair it.
I was driving home from work and i heard a noise comming from the engine. I pulled over and saw the the Copper hose that runs right along side the valve cover on the passenger side. and has that thick stringy fabrick around most of it. The hose goes starts at about the middle of the valve cover. In the engine. runs along side it bends around the backside of the valve cover and goes into the top of the engine where the throtle body is but the back of it closest to to the window. the hose literaly broke and disconnected. could this be repaired with a peice of another copper hose and welded or does the whole thing need replaced
thanks
Old Mar 31, 2005 | 08:42 PM
nolan1123's Avatar
nolan1123
Default please help
please help anyone?
Old Mar 31, 2005 | 10:38 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Could you take a picture?
Old Mar 31, 2005 | 10:54 PM
MikeC4's Avatar
MikeC4
I am thinking EGR piping here? and the noise is coming from the exhaust manifold where it connects. But from your description, I am not really certain? If this is what you are describing, and it broke, I would replace it with a new one.
Old Mar 31, 2005 | 11:20 PM
nolan1123's Avatar
nolan1123
what is EGR piping. and will this hurt the engine if i drive the car even though it sounds bad. but i will have to take it down the road to get fixed
I will try and take a pic tomorrow
thanks
Old Mar 31, 2005 | 11:27 PM
nolan1123's Avatar
nolan1123
does anyone know some good heat resistant tubing or pipe i can get to fill in the 2 inch gap on the pipe.
Old Mar 31, 2005 | 11:45 PM
MikeC4's Avatar
MikeC4
thanks
take a look at this picture. I have the EGR tubing circled. Is this what you are talking about?
Old Apr 1, 2005 | 08:08 AM
nolan1123's Avatar
nolan1123
Yes That is the exact tube im talking about.
Thanks for the picture.
I cant replace it with a factory hose because i got custom valve covers that the custom hose wont fit around. The tube had to be cut and put a piece of high temperature hose in the space. So im thinking the hose that was put there wasnt that great at handeling high temps.
I need to know wht would be the best way to fill that space in?
thanks
Old Apr 1, 2005 | 03:07 PM
bogus's Avatar
bogus
I think you need to revisit the custom fix route again.
I would have someone cut that line and braze in a new length to clear the valve cover.
Old Apr 1, 2005 | 09:18 PM
Brimis's Avatar
Brimis
You might want to drive the car to an Auto store and see if they can match it up. The key is finding a store with a fellow who knows what he's talking about. Sounds funny, but I only go to Auto Zone when Joe's working!
To Hose melted
