injector size
Actually you could run 24s or the LT4 28s. Either size would give you good resolution for fine idle control. I ran the LT4 injectors for some time. You won't have any problems with either size.
36's would be my guess just based on the airflow you're looking to have with the extra displacement and AFRs.
http://www.gnttype.org/techarea/fuel.../fuelpage.html
Enjoy
I would think what really matters is how its tuned.
TJWong and Corkvett both have extensive experience with high performance vette engines. To ignore their recomendations would foolish in my opinion. They as well as others say 24# are what you need, then just get 24# and be done with it.
First of all how are you calculating injector size? Are you using the standard calculation that for every one Hp at WOT that one Hp requires 1/2 pound of fuel per hours? Or otherwise known as the BSFC constant? Or otherwise known as BRAKE SPECIFIC FUEL CONSUMPTION.
If you run the calculation for injector size which is what a lot of people do using a BSFC constant of .50 and a maximum duty cycle of 80 % or .80 it would look like this:
Horsepower x BSFC / Number of injectors x Max duty cyle
For example for a 500hp engine where a BSFC = .50
500 x .50 / 8 x .80 = 250 / 6.4 = 39.09 lbs/hr
One also has to remember that this is all theoretical. In reality for a normally aspirated street engine a BSFC is more likely .40 or even as low as .30. Using those numbers for the same 500hp engine you can come up with either 31 or 27 lb/hr injectors. And at the same time if you change the maximum duty cycle to .90 you can come up with 24 lb/hr. In our F stock eliminator car which has a 355 LT1 which dyno'd on a SuperFlow engine dyno at 535Hp, we run 19 lb/hr injectors. This car runs 10.70's, depending on conditions we can "tweak" the fueling by adjusting the rail pressure up or down.
The other issue on 99% of all street engines is how long are you actually running at peak power? This is the time that you will be requiring the peak fuel capacity. It is here that is where its very important that your complete fuel system is up to snuff. I can't begin to tell you how important that is. I have had to tune several Corvettes that has had inadequate delivery. In these cases it doesn't matter what size the injectors are is you can't get the fuel to them.
The first thing I do before making full power passes on the dyno is to make moderate passes below the redline to check for proper fuel pressure or tell tale signs of fuel starvation. Once I determine that fuel delivery is adequate, full power testing can begin. We run stock 24lb injectors on Vortech or prochraged blown F and Y bodies. Granted their kits do come with FMUs, but they work. It is better in case of a blower to install larger injectors and get the PCM recalibrated. But for 99% of all NA 383 engines that I see, we run 24's on them. The smaller injectors give better tunability in the low end as compared to their large capacity cousins.
