I decided to go carbed,and I need to know what I do with the wiring harness and the computer.do I leave them in there and tie them back or can I ditch them all together?
The 85 ECM harness is joined with another harness that connects under the battery on the firewall,
you can pull the ECM harness through the firewall and separate it from the other harness, which, connects to the starter, alternator, driver side coolant sensor, oil pressure etc. This way your dash will still get info
