C5 rims
Old Apr 1, 2005 | 05:25 PM
seering's Avatar
seering
Default C5 rims
OK looking at getting a new set of rubber to go on some rims
Rims are
18x9.5 rear with +65 offset
and
17x8.5 front with +58 offset.
I think these are off of a newer C5
Currently i have 255/17 on the front and
285 on the rear
(factory stock)
Any recommendation on what would be a good size that would look and perform well without adding to problems with ABS or traction control?
Old Apr 1, 2005 | 05:34 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
If you have an 88-96, yes they'll fit just fine.
The 8.5" C5 and 8.5" lateC4 wheels have the same dimensions.
The rear C5s will stick in 1/4" over your stock 9.5" rears.
Old Apr 1, 2005 | 08:20 PM
CorvettePoker's Avatar
CorvettePoker
Will the stock C5 wheel fit an 85' with spacers? If so...what thickness spacer?
Old Apr 1, 2005 | 08:29 PM
stock86vette's Avatar
stock86vette
Im running C5 Y2K's on my 86' with 1" spacers.... Fit like a champ
Old Apr 1, 2005 | 08:33 PM
CorvettePoker
Any pics of your vette with the rims on? Curious to see what it would look like! Thanks for your reply! Ken
Old Apr 1, 2005 | 09:12 PM
stock86vette
Ken, im not sure how to post them..... PM me your email and i'll send them that way if you would like.
Old Apr 1, 2005 | 09:23 PM
MYCoupe's Avatar
MYCoupe
Rims are
and
285 on the rear
(factory stock)
You can reuse your 255/45/17 tires up front and go with 285/35/18 out back. It will be a perfect fit. Your speedometer wont even be off and the ABS will be happy.
To C5 rims
