Checking/Inspecting Tie Rod Ends
Old Apr 1, 2005 | 06:32 PM
Dolfan's Avatar
Dolfan
Default Checking/Inspecting Tie Rod Ends
I just replaced the rear half shaft u-joints and now I was thinking of geting things realligned. With 16yrs and 72K miles I was wondering about the tie rod ends.
How can I check that they are still good?
Visual inspection they appear fine, what to look for?
This is better to do now then get everything aligned, Right?
Would this "tighten" up the feel and handling if they are suspect?
Old Apr 1, 2005 | 07:35 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Jack up the car, put your hands at 9 and 3 o'clock and pull back and forth if there is a lot of movement then it may be tie rod related.
Put yor hands at 6 and 12 o'clock and pull back and forth if there is a lot of play you ball joints need looking at.
Old Apr 2, 2005 | 11:47 AM
Dolfan's Avatar
Dolfan
That makes sense to check them at 9 and 3 o'clock. Not sure when they hold up over time. Just thought it migt be good to update thee parts and get the whole deal aligned and set for a while.
To Checking/Inspecting Tie Rod Ends
