coolant change
Old Apr 1, 2005 | 07:38 PM
squalsvette's Avatar
squalsvette
Default coolant change
hey guys.....i have a 95vert six speed......when i first purchased it last year i checked the coolant and it was black so i took it to the garage and they flushed the system with the machine and put the green stuff in.....this was last year..no leaks no problems ..runs .201-215..should i flush the system again? thanks guys
Old Apr 1, 2005 | 07:47 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
How does it look?
Fresh coolant is a lot cheaper than new radiators, heater cores, etc.
It's your call, but I wouldn't go more than two years
Jack
Old Apr 1, 2005 | 09:02 PM
tempest's Avatar
tempest
won't hurt to change the coolant.
if it is running above 200 while cruising on the highway i would pull the shroud to see if there is any debris blocking the radiator.
To coolant change
