MAF Burn off relay/system
Old Apr 2, 2005 | 12:35 PM
Red Runner's Avatar
Red Runner
Cruise-In I Veteran
Default MAF Burn off relay/system
My 87 is setting a 36 code. I replaced the MAF relay and cleared the code only for it to return. I look through my manual and in it also indicates to replace the power relay. So I looked around on the vendor site's and no one lists a power relay for any year after 86. Question is there a power relay for the 87 and if so what is the part/catalog number I can use to obtain it? Second if there is not a power relay what could it be? Could the new MAF relay be bad? Or is there something else in this circuit that could set this code? Thanks in advance.
Old Apr 2, 2005 | 12:40 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Both relays are the same and both are behind the battery
Old Apr 2, 2005 | 12:47 PM
AGENT 86's Avatar
AGENT 86
http://members.shaw.ca/corvette86/Code%2036.pdf
Old Apr 2, 2005 | 01:02 PM
vader86's Avatar
vader86
Both relays are behind the battery, and are the same part.
If you replace both and the code still sets, its the MAF itself.
Old Apr 2, 2005 | 01:50 PM
Red Runner's Avatar
Red Runner
Cruise-In I Veteran
I will replace the other one as well. Thanks; AGENT 86 and vader86 for the quick help. AGENT 86 nice link I have downloaded the pdf for future reference.
To MAF Burn off relay/system
