I need to know the best way to install the seal in the timing cover for the WP drive shaft. I have destroyed 3 seals during the install.
The seal appears to actually have two seals; a front (tan) and a back (black). I think I need to fold the rear seal towards the front and then try to slide it over the drive shaft but I am concerned about it leaking. I thought I might need to pull the timing cover, install the seal and then put the cover back over the shaft but the result would be the same, the seal has to alide over the shaft. My Haynes does not discuss this issue so I am looking for help!
Just finished putting the front of my engine back together today to get rid of the oil leaks...DONE!!! I have MUCh experience with this seal (done it 4 times now). It's definately easier to get the seal in if the cover is off. However, you will have to lower the oil pan to get the timing cover off and then on again. If you have an LTI (don't know about the others)...this requires removing the Oil Filter Bracket as well (one of the oil pan bolts is above it).It takes 2 people to put it on while still on the car. I held a socket over the seal (obviously same diameter) and had my buddy tap (more like bang) it on. All in all...it's definately less work to do it while still on the car. It's a tight little mother and always wants to **** to one side. As for the 2 seals...they will have to be pushed forward to get it onto the shaft...there is absolutely NO way you can have the black seal facing backwards toward the gear. There's a possibility it will leak again...I've had more than my share of crappy seals that I've put on. Hope this helps.
Put the seal on the sleave that goes on the shaft to connect the water pump the shaft. Then slide it on. I destroyed 3 before I figured it out. The sleave is the same dia. as the shaft.
Tried that and destroyed seal #3. The good news is that I got a new seal, folded the black lip forward, greased it up and it went right on!
Now I need to figure out the routing of 2 vacuum hoses but that will be a different post.
Hate to say it but I think you are headed towards #5. The proper way to do it is to debur the connecting shaft and oil it.Fit the seal on it,oil the hole,spline and put the shaft on the spline.Use a deepwell socket that is just slightly larger than the connector and tap the seal off the connector into the hole. Put her togther.
The key to installing it is the oil use it everywhere the seal will touch.
Why don't you go with an electric water pump, then you don't need any seals. Maybe you could wrap the shaft with a thin layer of teflon tape to help protect the seal.
