ZZ4 engine build UPDATE [PICS!]
Old Apr 3, 2005 | 08:17 PM
NUckINg FuTS's Avatar
NUckINg FuTS
Default ZZ4 engine build UPDATE [PICS!]
This weekend I was looking foward to installing my oil pump/pickup and Hamburger's oil pan, but the oil pump stud FedEx was to deliver didn't show. So, onto plan B...
This is the hardware being used in today's project. Dart Pro 1 aluminum heads, Victor Reinz Nitroseal gaskets, and ARP head bolts.
I used permatex thread sealant on all the head bolts.
Here's a pic showing the shapley 64cc combustion chambers and 2.02/1.60 valves.
Pics of the square shaped exhaust ports.
This pic shows the fairly large 200cc intake ports along with the 1.437D dual valve springs (good for .620" lift), Compcams guide plates, and ARP 3/8 studs.
Pic of a Nitroseal head gasket installed. These are the same gaskets LPE uses on most their SBC's. They're .026" compressed and should give me a compression ratio of 10:1.
Couple pics of the heads mounted.
Final pic with the heads installed torqued in three steps to 70 ft/lbs and also a sneek preview of the Moroso valve covers I will be using (still need to drill holes for the oil cap and pcv).
Here's the link to my first update: http://forums.corvetteforum.com/show....php?t=1052753
Old Apr 3, 2005 | 08:52 PM
dock351's Avatar
dock351
St. Jude Donor '06
Beautiful! Keep 'em coming!
Old Apr 3, 2005 | 08:59 PM
MaxLean's Avatar
MaxLean
Are those cast pistons?
Old Apr 3, 2005 | 10:00 PM
jp2002ls1's Avatar
jp2002ls1
Hypertectic LT4 pistons.
Old Apr 3, 2005 | 10:55 PM
rrubel's Avatar
rrubel
Very pretty. I like the fuel pump blockoff plate.
What's a Nitroseal head gasket?
[RICHR]
Old Apr 3, 2005 | 11:08 PM
88BlackZ-51's Avatar
88BlackZ-51
what are those heads supposed to flow?
Old Apr 3, 2005 | 11:32 PM
NUckINg FuTS
According to dart's website. 264cfm at .500" lift on the intake & 180cfm at .600" on the exhaust.
Old Apr 3, 2005 | 11:39 PM
NUckINg FuTS
[RICHR]
Made by Victor Reinz (Dana corporation). Nothing special about it just that it has a .026 compressed thickness raising compression .5 points and is made for iron block/aluminum heads part #5746.
Old Apr 4, 2005 | 12:49 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Those heads look like a quality set.The stock pieces dont even come close to those!Btw what size/kind of pushrods will you be using and what about the rockers?Sorry if I missed it in a previous reply or post.The project looks like its coming along great.
Old Apr 4, 2005 | 01:03 AM
350ws6's Avatar
350ws6
What quench distance are you running?
Old Apr 4, 2005 | 01:33 AM
NUckINg FuTS
Haven't bought the pushrods yet but plan on using a one piece design. As for rockers, I will be using crane gold 1.5 RR's
Old Apr 4, 2005 | 01:34 AM
NUckINg FuTS
Quench distance comes out to .051. .025 piston to deck, .026 head gasket compressed.
Old Apr 6, 2005 | 08:08 PM
350ws6's Avatar
350ws6
If you run a thinner shim HG you might have a more detonation
resistant engine due to the decreased quench height. Just a thought.
To ZZ4 engine build UPDATE [PICS!]
