Tunercat vs Tunerpro RT
Old Apr 5, 2005 | 09:13 AM
LD85's Avatar
LD85
Default Tunercat vs Tunerpro RT
I will just start to look at tuning my own chips for my engine only here in the next few weeks.
Any opinions on which is better/easier to use from the above choices, Tunercat vs Tunerpro RT?
I have the Datamaster for logging and Burn 1 Chip 256/Chip burner from Moates.net as the rest of the package.
TIA
Old Apr 5, 2005 | 10:48 AM
mos90's Avatar
mos90
i like tunerpro rt. but that is just opinion. they are both good..
Old Apr 5, 2005 | 10:59 AM
LD85's Avatar
LD85
I forgot to mention, will Tunerpro RT work with Win-XP?
Old Apr 5, 2005 | 11:27 AM
mos90's Avatar
mos90
yes, it works great on xp.
Old Apr 5, 2005 | 12:22 PM
LD85's Avatar
LD85
Awesome, I wanted all of this stuff to work on XP with a newer laptop,
I love the fact that the Burn 1 does not need external power
Old Apr 5, 2005 | 05:42 PM
LD85's Avatar
LD85
OK, looks like I'm gonna go Tunercat
Old Apr 5, 2005 | 10:19 PM
Insane1's Avatar
Insane1
I believe TunerCAT is the only one that has the def files for the 85 ecm unless you have swapped it out for something else. I want to learn tuning also but am having a hard time finding the software.
Old Apr 7, 2005 | 04:51 PM
LD85's Avatar
LD85
WOW, I burned my first chip!
It was soo exciting, I think I wet myself when I did it too!
Anyway, the Tunerpro RT double stacking feature is really nice!
I used it instead of Tunercat too burn the first chip!
Old Apr 7, 2005 | 05:23 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
What type of prom are you burning? You don't have to stack anything.. just set the device start address to the appropiate value
Old Apr 7, 2005 | 05:30 PM
LD85's Avatar
LD85
AT29C256K chip, double stacking is the way I was told to do it by another guy.
I tried starting the Hex and Chip starts but it would not work. Maybe there is a bug with the Burn1?
Old Apr 7, 2005 | 05:35 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
are you burning it for a 85 ECM or 86-89?
If its for a 86-89 set the DEVICE START to 0C000. Make sure you leave BUFFER START alone Theres no bug with the burn1, I do this all the time.. It saves headache of stacking the bin
Old Apr 7, 2005 | 05:55 PM
LD85's Avatar
LD85
It is for a 165 ECM, so I dont have to stack?
Old Apr 7, 2005 | 06:49 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
nope, just do the starts like I said and you'll be fine
To Tunercat vs Tunerpro RT
