Something weird with LT1 double roller timing chain conversion
Old Apr 8, 2005 | 06:32 PM
93 ragtop's Avatar
93 ragtop
I found my box and that is the part no. I am using. I put mine in about a year and a half ago. Maybe they have redesigned the part, but it fit mine ok. At least I didnt notice any clearance problems.
Old Apr 9, 2005 | 12:25 AM
comp94's Avatar
comp94
VictorRussell
Are you planning on doing a cam/95 opti/timingchain cover swap when you put in the coyles timing chain?
Old Apr 9, 2005 | 02:29 AM
tjwong's Avatar
tjwong
Originally Posted by Corvette Kid NC
I've been running the Cloyes 9-3145 set for about 12K miles now with no problems. I'm wondering, do you have the end play on the cam set to spec? The manual gives a spec but is not real clear on all the details if I remember right. Anyway, I set it when installing the rear cam plug. Even if you haven't disturbed it, it may be off enough that it worked with a stock set but won't work with this one.
I went to the machine shop today and double checked the cam end play for myself. As far as I can tell it is not out of spec. There maybe manufacturing tolerances between the blocks and or Cloyes timing sets. I have not idea for sure which it is. But I also had a LT4 Extreme set that I set up on the engine and it fell in place without any issues. I ordered the new Cloyes part number this after noon.
Old Apr 9, 2005 | 05:10 AM
JTHVETTE's Avatar
JTHVETTE
Default Bolt interference?
Try this. Remove the cam retaining plate and counter sink the bolt hole to fit a "flat head socket screw". This should give you the clearance you need and then some. If you have any questions about this, email me.
Thanks, JTHVETTE
Old Apr 9, 2005 | 11:52 AM
Hotred94's Avatar
Hotred94
I have an LT4 hot cam and Cloyes double roller just sitting here waiting to be put into my 94. Two questions:
(1) Does the 3157 have the splines cut in the center hole to run the older style opti?
(2) I noticed the new hot cam does not have a stepped nose on the timing chain end. The papers that came with it indicate the cam will fit 84-96 engines. I haven't opened the engine yet to see the old cam, but should the new cam have a stepped nose or the older style non-stepped nose?
Old Apr 9, 2005 | 11:58 AM
STL94LT1's Avatar
STL94LT1
No, you will need to upgrade the opti and timing cover to the 95 versions, to run that timing set. You'll also need to run a electric water pump.
Old Apr 9, 2005 | 12:08 PM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Originally Posted by comp94
VictorRussell
Currently In the process of all of that bud.
Old Apr 9, 2005 | 12:12 PM
tjwong's Avatar
tjwong
Where did you get the HOT cam? If it does not have the step nose on the end of the cam it will not work in the block. Because that step nose mates to the front cam retainer plate that bolts onto the block. Roller cams were not introduced until late 86 if I remember right.
Old Apr 9, 2005 | 12:19 PM
VR'92's Avatar
VR'92
St. Jude Donor '03
Sorry for the fuzzy pic but heres a pic of the Cloyes hitting the bolts:
I've already filed the bolts down. Hoping that will work.
Old Apr 9, 2005 | 12:20 PM
VR'92's Avatar
VR'92
St. Jude Donor '03
Thanks, JTHVETTE
Thats a really good idea. I might give that a go If my filed down bolts don't work.
Old Apr 9, 2005 | 12:23 PM
VR'92's Avatar
VR'92
St. Jude Donor '03
Gosh I hope thats not what wrong. I don't know anything about all that. Probably have to have the motor out to work on that right?
Old Apr 9, 2005 | 12:38 PM
TwoFast4Lv's Avatar
TwoFast4Lv
TJ. I have had good luck with the following double chain sets.
Edelbrock timing sets
Comp Cams timing sets
Roller Master Timing Sets
I recently bought a Cloyes Heavy duty singal set for one of the projects cars but have not tryied it yet.
I need to get Your number BTW. Shoot me a line at
speed secrets@comcast.net
later man!
Old Apr 9, 2005 | 12:49 PM
  #33
Hotred94's Avatar
Hotred94
Oh gees... I'm just having one of those days! I'm really embarrised, I was looking at the back end of the cam? It does have the step nose, I just pulled one end out of the box and got looking at it.
As for the 3157 with no splines, my machinist buddy thinks he can make an adapter to work with the 3145. I'll have to talk with him once I get the engine open and see what's what.
Old Apr 9, 2005 | 12:57 PM
  #34
STL94LT1's Avatar
STL94LT1
Hmmmm, don't think I would want to try that. But, good luck.
You'll also need an electric water pump to use that timing set.
Old Apr 9, 2005 | 01:06 PM
  #35
Hotred94's Avatar
Hotred94
I have the Meziere pump--beautiful piece of work. It's finally getting warm enough that I can work on the car without freezing to death. I spent all winter just getting the hub and damper off.
Old Apr 9, 2005 | 01:34 PM
  #36
tjwong's Avatar
tjwong
I doubt that your machine shop can properly index the opti in relation with the cam. Its a small shaft to begin with, and by the time he is through trying it, you have spent more in labor cost than the cost of a conversion to the later opti. The late opti or rather the vented style are around $230 from Sam Taylor Chevrolet. Couple that with a used 95 timing cover for about $40 or less and you have a complete system. Its not worth the trouble or headaches.
Old Apr 9, 2005 | 01:37 PM
  #37
STL94LT1's Avatar
STL94LT1
Also, Lunati makes an affordable timing set for the 1992-94 LT1.
Summitt part # LUN-93094
Price: 109.69
To Something weird with LT1 double roller timing chain conversion
Old Apr 9, 2005 | 02:09 PM
  #38
Hotred94's Avatar
Hotred94
You're probably right about indexing the shaft. I saw the lunati timing set in the summit catalog but it shows a price of $175. Maybe they dropped the price. In any case, I should give a lot of thought to a new style conversion.
Old Apr 9, 2005 | 06:31 PM
  #39
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Yeah, the motor or the transmission and flywheel. However, just to check the end play you wouldn't have to do all that.
Old Apr 9, 2005 | 09:16 PM
  #40
ztrips's Avatar
ztrips
The lunati set is not a true roller. You might as well just stick with GM and not worry about the conversion to the later opti...
