Dyno tune first 3 pulls
How does it idle?So........something mechanically wrong with the car, huh?
With that reply from the mail order tune I feel safe in assuming who did your tune. Proabbly the mail order tuner with out a dyno to work with doing numerous combo's...but its mechanically wrong when they go bad.
Great numbers!!!!!!!!!!!! You should hit 410+ rwhp
yes, "mechanically wrong" His thought was bad O2 or injectors, vac leak, etc… I think the tuner made a mistake in the tune because my VIN wasn't inputted correctly. I plugged in my scanning software it came back with a different VIN. If he entered the wrong VIN then he might have made another mistake someplace or he mixed up computers and sent me someone else’s tune?????? Don't know. All I know is the car wouldn't run. Gray smoke, black smoke... I had to pump the gas pedal to get the car to run and I had to play with the throttle to keep the car from stalling.
It seems mail order tuning is a hit or miss. Sometimes it works and other times it doesn’t.
This mail order tuner HAS a dyno and he suggested I bring the car to him. The distance and the fact I don’t have a truck to tow, I decided to take it someplace closer.
jeff
Car starts great now, idle is good. The exhaust Doesn't smell like a gas can anymore. Black smoke/ dark gray smoke is gone.
John will tweak the tune once I get the exhaust worked. Doesn't make sense to tweak the program if I'm going to change things.
I have an appt with Robert for next month. i hope to find some extra power with the new exhaust.
As for which side is which on the dyno sheet, AF. The red line #2 is pass and the blue line #1 is driver.
Robert
Robert
I'm getting a tweak in Va Beach on Monday so this should be corrected on mine.
I'm interested in your project since I have just undertaken a similar stroker project based on a 396. Mike Norris is building mine to be complete by the end of the month. I'm hoping for similar results... CNC heads & intake, 30# injectors, 58mm TB, Comp 306 cam, Lunati race crank, H-beam rods, JE pistons (~ 11.25 CR), Meziere HD elec water pump, Fidanza alum flywheel, MSD 6AL, TPIS long tubes, Random Tech bullet cats, Power Effects, 4.10 gears. Whatcha think???
How about sharing those dyno results with your Grand Sport brethren? You know we have our own Dyno Page.
It is commendable that you don't want to start a flame war over your mail order tuner. The one I'm thinking of does very good work but let's face it, nothing can beat an on-site dyno tune!
Are you still in Germany or back stateside yet?
Jeff -- You are welcome to post exhaust photos on the GSR Photo Gallery. Do you really think a 3" exhaust that narrows down to the 2.75" PowerEffects capsules at the rear would have any benefit over an all 2.75" system? Just wondering if it would be worth the expense.
On Friday during the first 3 pulls I had a new Bosh O2 on the driver's side and an older AC O2 on the pass side. John replaced the old o2 with a new AC O2 and the lines moved closer together.
On the passenger side the little gray plug that holds the front o2 to the piece of metal on the block broke and the 02 wiring harness burned on the headers. This happened a few years ago. I cut off the damaged wire on the wiring harness and used a GM O2 harness repair Kit.
Most likely there is a wire resistance issue from the repair which could be why one side is different. having the same brand of 02 might help as well.
John said a .5 split or less is ok. I have .5 or less across the board. He said another possible cause for one side different then the other is injectors.
---thanks... I was hoping for numbers closer to 500 at the flywheel but I think I can get close with a 3inch exhaust.
--- I think your heads will flow a little better then mine and with more cubic inches you will easly make the 500hp mark.
---Sure, My car is already up there with 355rwhp from a stock 350 with a LPE top end kit.
IM me the mail order tuner's name. Are you still in Germany or back stateside yet?
---I moved back 3 months ago... I've been really busy working on the car, new house, new job, etc... I would like to attend the C4 bash next month but not sure if I have time....
---In my case I bought the EM long tubes, and random cats with 2.5 inch pipe for a corsa system. I didn't know corsa used 2.5inch were the stock is 2 3/4!!!!
Since I have to change all of that i might as well go 3 inch all the way back. I just ordered power effects 3inch flanges for the PE mufflers.
and seems better on throttle response. I will send over my dyno sheet and exhaust pics to the Registry , your list on your 396 is alot like my build. jeff
thanks
jeff
