Just got back from the tuner. The red line is the first pull with the Mail order tune and the 3rd pull is where the car is now after changing a few things. He will continue tuning monday... I should be making around 400 to 410rwhp. He said I would make more power if I had 3inch exhaust all the way back.
SDPC 383 short block
GM 847 cam
SDPC Stage III heads (LPE machines the heads for SDPC)
LPE LT4 manilfold.
58mm TB
EM long tubes
PowerEffects
Wow very nice gain; looks like about a 10% boost from tuning.
I tend to agree that with about 470-490chp you should be running 3" true duals. You need about 2.2cfm/chp or about 1,100cfm in your case. A 2 1/2" pipe can flow about 560cfm or 1,100cfm with duals. Which would would put you just about at the limit of a set of 2 1/2" duals.
Nice numbers! Congrats on the results. I would look into the exhaust a little deeper. dual 2.5s are sufficient for 500CHP so I would go dual 2.75 max unless you plan on doing more for HP. Keep in mind it's good to have little back pressure...little being key word. Only certain cam profiles warrant NO back pressure at all and I am uncertain of yours. Good luck
Nice torque bump there on the chart. Do you have an X-pipe on the car right now?
That first run it was definitely running lean, over 14 all the way. Some here might comment that you can go way richer but John doesn't seem to take it beyond the low 13s. Difference of opinion. And then he backs up the data log by pulling a plug and reading it. If you get a chance, can you ask John which side of the engine is # 1 and # 2 on the chart? I have the same divergence between the two and think my driver side is richer.
I saved the jpgs and hit them with some gamma correction. It brings out the lines a lot better.
The Power Effects are 2 3/4. Im running the same ones on my car. I agree tho...its time to upgrade. I need to as well.
I took my car with Power Effects to a muffler shop, had them build it all 3" from header collector/ 3" cats/ x-pipe all the way to the Power Effects capsules. Sounds Wicked
The mail order tune wasn't working at all for my car. I had problems keeping the car running. If I stoped at a stop light I would have to keep my foot on the gas to keep the car from stalling. Now after john looked at it she runs and sounds good... I went by the shop today and he thinks I should see around 420rwhp with 3inch exhaust all the way back. the mail order tuner said there had to be something mechanically wrong.
Thanks... I'm going to take John's advice and go 3inch all the way.
I'm using the EM long tubes with 2.5 inch pipes with the power effects 2 3/4 muffler system. There isn't a X-pipe only a resonator. Should I cut out the resonator and install a xpipe???
John said he would add more fuel to the program. Take out a little down low and add a lot more up top.
I asked him which side was which but now I can't remember. sorry... He starts talking about all these numbers and setting... Its hard to keep it all straight in your head; I've never tuned a car before. He did say the passenger side O2 is reacting slower then the driver side. The passenger side O2 is a year or two old and the driver's side is brand new. I went out and bought another O2 and john is going to replace the older one to get the two lines to come together.
I’ve decided not to mention the mail order tuner’s name in this thread. Why, because I’ve seen the other threads and it just turns into an argument. I will tell you offline who the mail order tuner is but please don’t post it in this thread. My intention wasn’t to make a mail order tune bashing thread. I just wanted to show the dyno sheet and see what everyone thought. John said I should be able to pick my car up Monday night and I’ll post the final numbers. Thanks
While Robert is under there cutting and welding would be a good time to put in an X-pipe on the 3 inch pipe. They are supposed to add 5-7 Hp but I don't know anyone who added an X-pipe separately to prove the HP gain. You already have the torque curve bump at 3000 that on mine I thought was attributable to the X-pipe. I guess that's the LT headers working with the cam at that rpm range.
You do have one advantage over my setup. You can crank down the noise level in your power effects for cruising. My setup is static and when it's too loud I just have to put up with it. A low speed uphill pull in my car gets to be too much.
I'm going to call robert monday and make an appt. to have him work on the exhaust. Does he fab and install everythig in one day or do you have to leave the car there for a few days?
As for the x-pipe, I thought the resonator acts like an x-pipe.. ??
robert
Robert did my work in one day. If you were going to order new mufflers like Magnaflows you'd have to do that in advance. You might want to talk about ordering an X-Pipe. He makes up the exhausts from lengths of straight or pre-bent mandrel tubing he has in stock. Cuts up pieces and welds them to fit whatever space is there, and makes a system that is totally custom. He's an artist with a sawzall.
The resonator mostly tones down the sound. It doesn't really have an open flow like H-pipes or X-pipes to get reflected pulses going to the other side.
