LT Hub bolt, is it really necessary?
Old Apr 9, 2005 | 02:48 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Default LT Hub bolt, is it really necessary?
Seriously, Iwas installing the HUB and when I was done I quickly assembled the acessory alumnum bracket to see if the belt lines up and it needed to go in almost 1 belt tooth in. Since the installer Kent Moore tool didnt work(no need to explain, has to do with custom crank.), I went ahead and installed the center hub bolt, and torqued it down to 75#'s(pre service manual) then lightly tapped it, and when it aligned up after a few tries, I retorqued the bolt, and snap, it broke. So, now I need to find a new bolt, a tap, etractor. The problem is my crank is drilled really deep, so an extractor will need to be a long one, and the drill.
So does that bolt need to be there, it is pressed on, and it wasnt easy getting it off. No oil or pre lube was used.
Old Apr 9, 2005 | 03:01 PM
STL94LT1's Avatar
STL94LT1
Yes, the hub bolt definately needs to be installed. If that hub worked loose at 6500 rpms, it would be a disaster.
Old Apr 9, 2005 | 04:37 PM
steve40th's Avatar
steve40th
Thats what I figured.
Old Apr 9, 2005 | 04:39 PM
tjwong's Avatar
tjwong
Steve you must have a Callies crank? They tap the center bolt well into the main webing for additional strength. On the last engine I built it was 3.5" deep into the crank snout.
Old Apr 9, 2005 | 06:37 PM
steve40th's Avatar
steve40th
Yep, Callies Stealth
Old Apr 9, 2005 | 06:40 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
The old Chevy inline sixes (except for the 292) didn't use a bolt there. But that being said, I wouldn't want to be w/o it on a high performance V8.
Old Apr 9, 2005 | 07:28 PM
ralph's Avatar
ralph
I dont think Chevy coulda made it any more difficult to deal with that damn LT1 damper setup. And if you're using an ATI damper, they add to the degree of difficultly. Had to pull my nephew's engine when he cross threaded the damper bolt and couldn't get another one started. And if you've ever tried to install an ATI in the car you'd understand.
Old Apr 10, 2005 | 05:40 AM
steve40th's Avatar
steve40th
I guess I am glad I didnt go with ATI, as this is crazy. No more LT1's for me, its either L98 or LS1 types.
Old Apr 10, 2005 | 04:17 PM
Texas CE's Avatar
Texas CE
Man I agree!!!!!!!!! The LTx has got to be one of the most frustrating engines to work on in the car. There is almost no room to work, position tools, the stupid hub/HB has to be removed/installed on the vehicle separately, replacing the spark plugs & wires(especially on the left side) leaves you looking like you were in a fight with a leopard and the leopard won, the stupid water pump sits so tight on the left side you cannot see if you got the gasket on correctly, and on and on and on!
Well I feel better!
Old Apr 11, 2005 | 03:24 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I always use a new bolt ,the old one always breaks.
ATI has the right bolt if you talk to them.
I got the right one for my cola crank from ATI and sure it was free.
NOT.
$399.00 PLUS THE BOLT.
Old Apr 11, 2005 | 03:28 AM
steve40th's Avatar
steve40th
400 bucks for the ATI and the bolt? They wouldnt sell you the bolt seperately would they?
I havethe Callies crank and it is a longer bolt, thats why the Kent Moore Tool didnt work either way.
Old Apr 12, 2005 | 01:15 AM
REDC4CORVETTE
With the cola crank the LT1 balancer would not fit and the cola crank is keyed.
I needed a balancer made for the LT1 with the proper clearence for a standard chevy crank.
The bolt and washer was $22.00 more
Old Jul 22, 2005 | 11:56 AM
steve40th's Avatar
steve40th
ttt
To LT Hub bolt, is it really necessary?
