Heated O2 Sensor Power Requirements?
Old Apr 9, 2005 | 08:52 PM
Dougs 90's Avatar
Dougs 90
Default Heated O2 Sensor Power Requirements?
Those of you that have upgraded to the three wire O2 from the one wire O2..How did you wire the power circuit and where did you obtain the power? What is therrent draw for a Heated O2 sensor?
Thanks,
Doug
Old Apr 9, 2005 | 08:57 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
i think i read on the forum that some have tapped into the wiper motor harness for a 12v switched source. i will be trying this as i no longer have a wiper motor (won't fit with my tall valve covers).
Old Apr 9, 2005 | 09:00 PM
scorp508's Avatar
scorp508
You can get a SPST relay and tap into the fuel pump relay for your signal and then hardwire a line to the junction block behind the battery.
Old Apr 9, 2005 | 10:53 PM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
I basically did like Scorp suggested on my 90 except I used the 1-4 upshift relay (right next to the battery) for the switched power source.
Old Apr 10, 2005 | 12:40 PM
Dougs 90's Avatar
Dougs 90
Where is the Fuel Pump Relay?
Thanks,
Doug
Old Apr 10, 2005 | 03:05 PM
corvette90's Avatar
corvette90
there was a thread a time ago, which dealt with this issue..
i measured the amperage , its under 1 amp...i wired it in the 1-4 relais
Old Apr 10, 2005 | 03:50 PM
steve1ph2's Avatar
steve1ph2
iv located the 1-4 relay right behind the batt. the wire colors are green, green white strip, blue, pink with black strip. the o2 has 3 white white and black. which wires did you connect. thanks
Old Apr 10, 2005 | 06:23 PM
Mad-Mic's Avatar
Mad-Mic
i need to do this myself.
any pics Steve?
Old Apr 10, 2005 | 06:27 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
I don't have any Cats or EGR grap so I hooked into the main power wire that went into the relay for the electric AIR pump.
Old Apr 10, 2005 | 06:37 PM
Mad-Mic's Avatar
Mad-Mic
do you have a pic of this connection?
please email me at Mad-Mic@comcast.net
Thanks!
Old Apr 10, 2005 | 07:54 PM
Dougs 90's Avatar
Dougs 90
Default Thanks Everybody!!!!!!
I got it done today, I ran a relay off the fan input and took 12V fused @ 5amp from behind the battery for the O2 power. There was a nice ground for the relay in in the front where the headlights drop down. And I used the ground Scorp suggested behind the oil cooler. I just tapped it into another wire there as I couldn't get to the bolt my hands are too big. I cut off the old connector from my old O2 sensor and soldered it onto the end of the O2 Signal wire. When it was all said and done, it looks really good too! I drille a hole into the rediator shroud to screw the relay on and it looks like it belongs there!
Thanks again to all for the help!
Doug
Old Apr 11, 2005 | 11:43 AM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
this is exactly what I did
Old Apr 11, 2005 | 05:07 PM
fsr402's Avatar
fsr402
St. Jude Donor '06
Thanks!
You can't see much but here it is.
Old Apr 12, 2005 | 04:15 AM
steve1ph2's Avatar
steve1ph2
left my o2 at work last night so seems i have to wait till wed for more input
Old Apr 12, 2005 | 01:16 PM
VMAX451's Avatar
VMAX451
Initially 5.5 amps for 2 Bosch 13190's. It goes down to less than 3 amps within a few seconds.
To Heated O2 Sensor Power Requirements?
