Code 34!
Old Apr 10, 2005 | 08:03 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Code 34!
Turned out to be the MAF relay again
That's the second on in a little over two years!
Any one else had similar experience?
seeya
Jack
Old Apr 10, 2005 | 08:16 PM
sniperdiver37's Avatar
sniperdiver37
are you running a K&N filter?
The oil from those kind of filters gets sucked up and hangs on the MAFS.
Old Apr 10, 2005 | 08:22 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
No straight AC Delco filter
I am buying Echlin relays, not the cheap stuff!
seeya
Old Apr 10, 2005 | 10:08 PM
Pete K's Avatar
Pete K
About every 3 years or so, my car throws a code 33 or 34. I swap out both relays and the problem goes away for another 3 years. I do not get it but I don't care to trouble shoot it either. Cheap, easy fix.
Old Apr 11, 2005 | 02:57 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
You could have a short in the maf.
GM says the relays are to be serviced or replaced on a regular service basis,what ever that means.
To Code 34!
