U-joint/Strut Rod question
Old Apr 11, 2005 | 12:51 PM
Square's Avatar
Square
Default U-joint/Strut Rod question
I am trying to replace the U-joints in my half shafts. I am following Scorp's photo doc of the procedure (thanks Scorp!). I have removed the Tie Rod bolt, Camber Bolt and Leaf Spring bolt. The current problem I have is that I am trying to hammer out the Strut rod, but I think it is catching on the little bottom lip in the socket. I can hammer it all the way up, but not all the way down and out. Anybody run into this before?
Old Apr 11, 2005 | 12:56 PM
scorp508's Avatar
scorp508
That thing can be a pain. I've had to use a prybar before to wedge it out of place. If you can move it down some you may be able to get a metal rod between the knuckle and the rod and pry it out. Good luck.
Old Apr 11, 2005 | 01:26 PM
Square's Avatar
Square
WOW! That was quick!
Thanks Scorp!
Old Apr 15, 2005 | 12:29 PM
Clay Assassin's Avatar
Clay Assassin
Scorp,
You got a tutorial on the driveshaft too?
Or is that one just too easy? I haven't looked yet.
Thanks,
Old Apr 15, 2005 | 12:34 PM
scorp508's Avatar
scorp508
Sorry I Don't. It is easier than the halfshafts in that there is less to remove, but it can be a pain if you haven't removed the c-beam and driveshaft before.
1) Remove exhaust
2) Support engine with jack
3) Remove C-Beam
4) Remove Driveshaft
5) Do U-joints just like the halfshafts
6) Do 1-4 in reverse
Old Apr 15, 2005 | 02:27 PM
CFI-EFI's Avatar
CFI-EFI
Am I reading this correctly? You are removing both ends of the strut rod? One end is enough. I found that rather than mess with the camber bolt and cam, and worry about alignment, it was easier to remove the outer end of the strut rod from the knuckle.
RACE ON!!!
Old Apr 15, 2005 | 02:49 PM
scorp508's Avatar
scorp508
RACE ON!!!
Actually you read wrong and I replied wrong. I was thinking the outter side of the rod and told him that part since most people prefer to do it that way instead of what my instructions say.
Old Apr 15, 2005 | 08:00 PM
CFI-EFI's Avatar
CFI-EFI
I saw "a metal rod between the knuckle and the rod and pry it out." and I knew you were addressing the opposite end that you recommend. At least now I understand how it got written that way.
RACE ON!!!
Old Apr 16, 2005 | 12:47 AM
Movnviolation's Avatar
Movnviolation
Default Driveshaft
Just took the driveshaft out of my 89 and it took me about 20 minutes.
I did not have to remove anything. C-beam, exhaust, nothing. There was enough room to slide it out the back. The Helms said to remove exhaust, C-beam, etc. The shaft came right out!
Mine was found to be bent, so I had a new one built. Aluminum, ouch!
Lost my high speed shake.
Old Apr 18, 2005 | 07:50 AM
Clay Assassin
Thanks Movn,
I looked at it this weekend, and it looks close, but I thought it may slip right out the back too.
Do you only have to unbolt the dif end, and the fron rnd slides off?
Old Apr 18, 2005 | 09:19 AM
rstackjd's Avatar
rstackjd
Ok, as long as Scrop is here answering questions. I tried to do mine this weekend following his instructions and IT BEAT ME - though it might have been becasue of a lack of tools.
I don't have a "suspension fork" (truth is, don't even know what that is) and could't get the tie-rod out to save my life so I said screw it, and put it all back together for another day. Is the suspension fork the only way to get that out? I tried tapping up on the bolt with a wood block between the hammer and bolt, but nothing.
As for the Strut Rod - so if I'm reading correctly, its ok to remove the outboard side instaed of the inboard? That would be great becasue it looks like I'd have to drop my exhaust to get the bolt out on the inboard side.
Maybe next weekend.
Old Apr 18, 2005 | 09:51 AM
jimcork1's Avatar
jimcork1
Default Fork
the suspension fork does work for taking apart the ball joint,, but it almost always tears the boot. I prefer to use a c/clamp press system and smite it gently with a 2 # hammer . But that is only my technique.
Old Apr 18, 2005 | 12:01 PM
CFI-EFI's Avatar
CFI-EFI
Maybe next weekend.
The "suspension fork" is also known as a pickle fork. They are used for separating tapered fit parts like the ball joints and tie rod ends. I prefer to remove the nut and thread it back on the ball stud, upside down. With the castles inward. With the nut screwed flush with the end of the ball stud to protect the threads of both, I give the stud and nut a sharp rap with a fairly heavy hammer. You want to make sure to hit it squarely to prevent damage. A large screwdriver or pry bar exerting a separating force while rapping can help if the parts are stubborn.
I prefer to remove the strut rod at the knuckle. That way you don't have to mark the cam to hopefully bolt it back in the same exact position to maintain your rear wheel alignment. Either end works. To me the outer end is easier for several reasons.
RACE ON!!!
Old Apr 18, 2005 | 01:32 PM
rstackjd's Avatar
rstackjd
Thanks guys - looks like next weekend we'll give her another go! I may be inept, but at least I'm persistent.
Somehow I just know I'll go through all this just to find out that the u-joints were just fine and the noise was the wheel bearings - but ah, well, then the whole rear suspension will be practically new.
To U-joint/Strut Rod question
