Need help reading chip
Old Apr 13, 2005 | 02:57 AM
black_89_vette's Avatar
black_89_vette
Default Need help reading chip
I found a chip that I used to use. I believe it was an Ed Wright chip.
I have since took my car to a dyno where a chip guy tweaked my chip a bit, but I believe he just saved the .bin from the original and tweaked it onto another chip.
So, I thought I have the original Ed Wright chip here, but when I try to open the .bin in TunerPro or WinBin, it just gives a bunch of 0's as values. It said device is not erased and device is programmable in PP2.
If it's not erased and it is programmable and it's just showing 0's, is the chip garbage or is it just locked out somehow?
By the way, I'm trying to use the 27C128 option under PP2 program. How can I tell if it's the right setting?
Old Apr 13, 2005 | 10:19 AM
tjwong's Avatar
tjwong
Is the chip indeed a 128k chip? If it is a 256k chip then the tuner may have stacked the program. In that case you have to edit the file with a hex editor to be able to read it. How large is the file that you read from the chip? If its 16k then its not stacked but if its 32k then it is. Another issue with the 256k chip is that he possibly had programmed the chip at a different starting address. But with that you should be able to open the file.
Old Apr 13, 2005 | 10:49 AM
Alvin's Avatar
Alvin
St. Jude Donor '05
If its meant as a 86-89 chip you should be able to read it as a 27C128 regardless if its 256 or 512.
It may be currupted or it may be locked. Ed Wright locks alot of his tunes.
Old Apr 13, 2005 | 01:33 PM
black_89_vette
I just looked at the file and it's 16 k. It was definitely meant for an 89, so I'm guessing it's corrupt somehow. I've had it in my console compartment for a few months just sitting there.
Old Apr 13, 2005 | 01:42 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
have you tried opening it in tunercat? It might be a 6E or 32B.. maybe he uses older programs even for the newer cars.
Old Apr 13, 2005 | 01:49 PM
black_89_vette
I've tried opening it in WinBin and TunerPro both with the 6Ev011.ecu.
I used that .ecu with my current chip and it seemed to read fine. I have another post if you've already looked at it, or not.
If not, if ya got time, could you?
http://forums.corvetteforum.com/show...26&forum_id=82
****EDIT****
I don't have TunerCat.
Old Apr 13, 2005 | 04:37 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
is the chip in question that chip.zip?
If so I just checked it out for you and it reads fine with tunercat. I don't use tuner pro so I couldnt' tell you the problem. Email the author mark and ask him.. he seems like a stand up guy.
Old Apr 14, 2005 | 02:26 AM
black_89_vette
No, it's not the chip.zip that I posted in an earlier thread. It's an extra chip that I can save a 16 k .bin file, but once opened it shows all zeros as data.
Alvin, when reading that chip.zip file in the other thread, did you see any major issues with it that I should remedy?
Old Apr 14, 2005 | 09:58 AM
Alvin's Avatar
Alvin
St. Jude Donor '05
Didn't really look threw it.
Its hard to tell anything by looking at a bin. But i will look over it to make sure theres not a crap load of timing or anything.
Post the bin that your having problems with and i'll see if I can open it.
Old Apr 14, 2005 | 11:04 AM
black_89_vette
Here's the .bin I saved off the other chip I had hanging around. I do believe it's the old Ed Wright chip I had done.
All I could seem to see was zeros as data.
http://www.geocities.com/sr383vet/blue.zip
Old Apr 14, 2005 | 11:17 AM
Alvin's Avatar
Alvin
St. Jude Donor '05
Yep, your right its blank.
My guess is your tuner tried tuning that prom first, erased it, then it wouldn't tkae a burn so he gave up and gave you anthor prom.
Old Apr 14, 2005 | 02:09 PM
black_89_vette
SO, is it junk now then? I mean, it's blank but it says it's not erased in PP2 software.
To Need help reading chip
