Spark Plug Gap Recommendation Needed.
Old Apr 14, 2005 | 09:58 AM
elkabong's Avatar
elkabong
Default Spark Plug Gap Recommendation Needed.
I am installing my 383 but I realized that I need to gap the plugs and I am not sure where to set them. I am running TFS 64cc chambers and the CR is around 10.3:1.
I am using Autolite 3924 per the TFS recommendation. What would be a good gap?
Thanks in advance.
Old Apr 14, 2005 | 10:50 AM
Nathan Plemons's Avatar
Nathan Plemons
Kinda depends on your ignition system.
I gap my LT1 @ .060 with no problems at all.
Old Apr 14, 2005 | 11:21 AM
elkabong's Avatar
elkabong
My Vette is a 84 and I just have a Accel Coil and Module. Everything else is stock. Maybe I am wrong but I thought a higher compression motor required a slightly tighter plug gap. Stock is 0.044 - I think.
Old Apr 14, 2005 | 02:21 PM
CFI-EFI's Avatar
CFI-EFI
Stock is .045" (BFD) and I would stick with it.
RACE ON!!!
Old Apr 14, 2005 | 02:45 PM
88421VETTE's Avatar
88421VETTE
RACE ON!!!
I beleive I gapped the plugs in my 406 at .045" is that right
Old Apr 14, 2005 | 02:56 PM
CFI-EFI's Avatar
CFI-EFI
That should be fine.
RACE ON!!!
Old Apr 14, 2005 | 07:19 PM
elkabong's Avatar
elkabong
Cool thanks.
Old Apr 14, 2005 | 08:07 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
I run the Autolite 606's in mine...they are gapped at .030...makes it idle a tiny bit rough but at the track it's perfect for WOT...btw, I just changed mine and the old ones looked like brand new after 20 months and over 300 passes at the dragstrip...not bad for $1.57 each...
To Spark Plug Gap Recommendation Needed.
