Which random tech should I buy?
Old Apr 14, 2005 | 01:54 PM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
Default Which random tech should I buy?
Round, Metal Matrix
7000 Series-- 2", 2-1/4", 2-1/2", 2-3/4", 3", 3-1/2" and 4" inlet/outlet
Round, Ceramic
8100 Series-- 2", 2-1/4", 2-1/2" and 3" inlet/outlet
Oval Ceramic
8000 Series-- 2", 2-1/4", 2-1/2" and 3" inlet/outlet
9000 Series-- 2", 2-1/4", 2-1/2", 3", 3-1/2" and 4" inlet/outlet
I'm going to go with 3"inlet/outlet but can't decide with series to go with. suggestions?
Old Apr 14, 2005 | 01:58 PM
bogus's Avatar
bogus
I would contact them and see what they suggest. Also, check with a vendor... get their opinions.
Old Apr 14, 2005 | 02:37 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Old Apr 14, 2005 | 03:37 PM
FELNGR8's Avatar
FELNGR8
Originally Posted by Bluewasp
Round, Metal Matrix
Round, Ceramic
Oval Ceramic
Considering where you have to put them behind the header collector you would want the round for space. I have no opinion on metal or ceramic matrix.
Old Apr 14, 2005 | 04:34 PM
tjwong's Avatar
tjwong
The metallic substrate cats are the least resrictive. And unfortunately the most expensive. An alternative would be a set of a Dynatech Headers metal cats which are available from JEGs or SUMMIT for about $149
Old Apr 14, 2005 | 09:00 PM
Hutch's Avatar
Hutch
Wish I could help you, Robert, but I don't recall which RT bullet cats I have installed. At any rate they're the round ones and I tend to think they were the metal substrate jobs. I have them installed behind my headers with stainless steel band clamps. I had two lengths of straight pipe cut to fit in their place for racing, but to be honest, I've never bothered with swapping them.
Old Apr 14, 2005 | 10:48 PM
MYCoupe's Avatar
MYCoupe
The Metal Matrix flow better. On a stock engine it probably wont make much of a difference, but on your modified engine it does.
Old Apr 14, 2005 | 11:13 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Get the Dynatechs...the inside is exactly the same as the RT's for less money.
Old Apr 14, 2005 | 11:57 PM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
Thanks guys. Checking Jegs, summit for the dynatechs...
To Which random tech should I buy?
