rough idle and dancing volt meter
Old Apr 15, 2005 | 10:24 AM
lakerat's Avatar
lakerat
Default rough idle and dancing volt meter
Hi all, I've been trying to figure out this small problem for some time now. At times, after she's warmed up, I'll notice a slight miss. The volt meter will also jump with the miss. This is only noticible when sitting at idle. There is no hesitation or lack of power at acceleration. Plugs, wires, IAC, battery, starter, fuel filter, etc... are pretty new. Any ideas?
Old Apr 15, 2005 | 11:02 AM
rick lambert's Avatar
rick lambert
Maybe this will help get some responses. But first thing I'd do is check the alternator connection.
Old Apr 15, 2005 | 11:11 AM
lakerat's Avatar
lakerat
Yea, I'll check them again. The alternator was replacecd two years ago.
Old Apr 15, 2005 | 01:45 PM
ls5454's Avatar
ls5454
I'm just guessing, but when I was fighting my bad IAC, the volt meter on the display (for the battery) would surge/fall at the rather poor idle. New IAC, no problem.
Old Apr 15, 2005 | 01:56 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
What year?
Check plugs, wire and cap.
Old Apr 15, 2005 | 02:27 PM
lakerat's Avatar
lakerat
new wires (Taylors) last summer. Dist. cap is the original, but appears to be good. No light shows when it's dark out. I'll have to check my records. Maybe it was the TPS I replaced. The IAC may be original. My receipts folder for this car is pretty thick.....
To rough idle and dancing volt meter
