I'm looking for a decently streetable cam for my LT4 that will be a bit hotter than the LT4 Hotcam but would still allow me to cruise comfortably in 6th gear on the highway with stock gearing. I would also like to have about 350-360 HP at the wheels once this is all completed.
My vette will have the following in addition to the new cam:
EM Long tube headers
No cats
Borla cat-back
K&N air filter
Stock 1.6 RRs
Extreme Duty LT4 timing set
New springs/retainers
Tuning by Ed Wright
From doing searches, I've pretty much narrowed my cam choice down to these three cams: Comp Cams CC306 (07-306-8), Comp Cams Xtreme Fuel Injection 230/236 (07-467-8), or the GM 846 (12370846) which is also known as Crane part #109831.
Do you think the above cams would give me the combination of drivability and horse power that I want? If so, which one do you think would be the best choice? Would one of these cams be enough to get me deep into the 12s?
Well, My motor is a 396 and the 230/236 cam is about right, just started about 2 hours ago for the first timein 6-7 weeks. The 847 would be too much for an auto and your LT4 though, I need brakes also. The 847 is a big cam, the CC306 is older technology that works great, and lots of guys have it.
For a 350 though the Hot Cam is sweet. I think it is an awesome cam, makes great power and is very dirveable. But the 230/236 cam is a little more lopey, so far as I just got my chip set up. I went frm the Hot Cam to the 230/236 cam and can tell the difference. Fora six speed it might be a better choice to get the 224/230(I know it is one step down from the 230/236) cam that Comp Cams makes in the XE line. Just my 2 cents worth.
I didn't see an Xtreme Fuel Injection 224/230 cam listed but you're saying that the Xtreme Energy 224/230 (07-503-8) cam may be a better choice than the Xtreme Energy 230/234 (07-306-8, CC306)? I don't mind a bit of lope at idle as long as it still has decent manners while cruising in 6th (in fact, I would kind of like a little lope).
Wes
I did the 503.....little more aggressive than Hotcam......IMHO a better choice than the 306....hot cam is definitely tried and proven
....driveability is a very personal thing in my opinion.....try to get a ride in a car with the cam of your choice....also tuning has a lot to do with driveability.....
LT4BUD, how well mannered is your 503? Any cam surge at cruising speeds? Also, how much power did you put down with this cam and how much did you increase your fuel cutoff rpm? I understand you have ported heads so you'll be making more power than me but I would just like an idea.
Thanks so much,
Wes
I am presently using a comp grind with 224/236 .536/.555 lift on a 112 LSA. It has great power numbers and very good street manners.
To order this cam with the above specs the Comp part number would be:
07-000-8 3314/3316 HR12 +4
The +4 denotes 4 degrees of advance to be built into the cam when Comp grinds it. Most of Comps off the shelf cams has 4 degrees ground into their cams. The above cam is based on their Nitrous grind and works well. It offers a nice note at idle, a little more aggressive than a LT4 hot cam and has much better street manners than the 306, or GM 847 cam. Also fuel economy is still decent with this cam, I can average around 24 on extended drives. This cam has virtually no cam surge, it can at very low speeds and if you intentionally lug it down.
For nice driveability I would stay close to the Hotcam's duration and LSA numbers, but with LT4 heads you can use more lift. TPIS has a cam real close to the Hotcam using 1.5 rockers. It would make a nice LT4 street cam with 1.6s, to get that extra lift. The Hotcam is a good cam and Ed Wright has a lot of success tuning around it. I would not go bigger than 226/230 @ .050", use a 112 LSA, and try to get your lift in the .550" to .570" range.
Wow, this is going to be a more difficult decision than I thought. Right now I think I'm leaning towards the Comp Cam 503 (276HR-12, 224/230). I think I read in one of LT4BUD's previous posts that he put down almost 370 rwhp with the 503 and stock manifolds. I should be able to use my stock rockers for this cam, right? What kind of springs and retainers would I need to accomodate this cam? Tjwong, what kind of horspower numbers are you getting with your Comp cam? I like the fact that you said your cam idled fine and cruises great on the highway.
Right now I think I'm leaning towards the Comp Cam 503 (276HR-12, 224/230). I think I read in one of LT4BUD's previous posts that he put down almost 370 rwhp with the 503 and stock manifolds. I should be able to use my stock rockers for this cam, right? What kind of springs and retainers would I need to accomodate this cam? Wes
I think this is my final formula for cam, rockers, springs, pushrods, rocker studs:
CCA-07-503-8 Cam
CCA-1318-8-16 Rocker Arm
CCA-26918-16 Springs
CCA-7940-16 Push Rods
CCA-4505-16 Rocker Studs
With 4.10 gears I get 24-26mpg on trips at 60-75mph interstate, around town pretty bad...
Surging stops about 45-50mph...
I now have EM headers, high flow cats....dyno tuning scheduled for weekend of May 14, I can tell you there is SOP improvement above the 370rwhp.....hopefully the dyno tuning will improve driveability, which isn't all that bad in my opinion.....
There is no hiding the fact this is not a stock cam......streetability is a personal thing, but IMHO this cam is pushing it, especially around town......
Thanks for posting the HP/torque graph. The HP gain is pretty good, but really only above 4800 rpm (also torque gain there). Does anyone know if its possible to boost the curves substantially in the mid-range as well as high end (especially the torque curve) with cam and heads in an LT4? Or is this really something that would need more cubic inches or supercharging to achieve?
Well guys, I know I've dug up an old thread but I just wanted to let you know I think I've decided to go ahead and go with the LT4 Hot Cam. It seems to be a perfect match for the LT4 and is a tried and true grind. Plus, I would maintain the driveability I want and would be putting down right around the numbers I'm looking for (400 chp with EM LTs). From looking at other posts, it looks like the only thing I really need to change out in my LT4 is the stock timing set with the extreme duty timing set. Am I correct in assuming this?
Thanks for the help,
Wes
Plus, I would maintain the driveability I want and would be putting down right around the numbers I'm looking for (400 rwhp with EM LTs).
With stock heads and a Hot Cam, there is no way you will see 400 rear wheel horsepower. You'll be lucky to see 350 rwhp. But, even at those hp #'s, I think you'll be real happy with the Hot Cam.
