*****AC Delco Water Pump Warning*****
Old Apr 16, 2005 | 08:21 AM
Texas CE's Avatar
Texas CE
Default *****AC Delco Water Pump Warning*****
I replaced the WP on my LT1 last week. I purchased a brand new, in the box AC-Delco WP. Before I installed it I decided to blow some compressed air through the openings to clean out any dust/lint from packaging. What came out was a bird's nest of corkscrew shaped aluminum shavings! These obviously came from the machining process the WP went through during manufacture. I then pulled the thermostat and front cover and found even more. The total amount was about the size of a golf ball.
I cannot believe that AC-D does not have an inspection process in place that would allow this mess to stay in the pump during final assembly.
Anyway, I thought I would pass this on.
Old Apr 16, 2005 | 09:55 AM
rwsduc's Avatar
rwsduc
Scary stuff there, thanks for sharing! Just curious, but how much does an AC Delco pump for an LT1 go for? I got a new GM pump for my 92 from Sam Taylor for $153. I haven't installed it yet, but before I do I'll pull the thermostat and take a look inside. Just looking down the passages, I didn't see anything that shouldn't be there. Anyway, good luck!
Old Apr 16, 2005 | 09:57 AM
rws.1's Avatar
rws.1
I would never have thought to do that with a new part. If that had made it into my engine ...
Old Apr 16, 2005 | 10:01 AM
JIMBO7's Avatar
JIMBO7
Wow, what a mess. Never thought to check this. Thanks for the heardsup!!!
Old Apr 16, 2005 | 11:07 AM
Powerdrive's Avatar
Powerdrive
Thank God you were not replacing the oil pump
Old Apr 16, 2005 | 11:44 AM
jfb's Avatar
jfb
I'd mail that ball of aluminum shavings to GM with a letter explaining where it came from.
Old Apr 16, 2005 | 03:36 PM
bogus's Avatar
bogus
Wow. That's NUTS!
Thanks!!!! That's a GREAT catch! Sad, but great.
That could do all sorts of damage to and engine... gum up the radiator, jam in the t-stat... block up a cooling journal. Damn.
I agree with jfb, I would put that in an envelope and send it, registered, to GM Corporate.
To *****AC Delco Water Pump Warning*****
