Cooling Issue Solved!
Old Apr 16, 2005 | 07:49 PM
glerma's Avatar
glerma
St. Jude Donor '05
Default Cooling Issue Solved!
I posted a while back and asked if my 235 to 240 degree operating temperatures were acceptable for my '95 sisx speed since I know that 'Vettes run a bit hotter than most cars. I checked the area between the radiator and condensor and it was almost totally clean.... I rinced the area out anyway and my temps were still too hot. Well... On a hunch... I went to a parts store and bought a new thermostat... regular 180 degree... not a 160.. replaced it and then added a bottle of Red Line Watter Wetter. After I buttoned it all up... I let it idle for a few minutes... then I went out for a spirited drive.... it stayed at 197 to 198 degrees the whole time! Only once did it touch 201 for a brief moment...then it went right back to 197. I know the Water Wetter can't be responsible for a 40 degree difference... I think my Stat. was bad.
Always check the cheap stuff first!! If that doesn't work...then move up in order of cost... That's how I have always done it.
Old Apr 16, 2005 | 08:36 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Congrats on a win.
Old Apr 16, 2005 | 09:04 PM
rws.1's Avatar
rws.1
I agree... always start with the simple, least expensive items
Old Apr 17, 2005 | 01:59 AM
jfb's Avatar
jfb
You could have tested your thermostat on your kitchen stove in a pot of water and you still can if you have the thermostat.
Old Apr 17, 2005 | 08:27 AM
Atok's Avatar
Atok
Yep, definitely your stat. BTW, my '95 runs at 188 - 190 at 65mph. Outside temperature doesn't seem to make much difference. I'm using a stock 180 stat that I replaced 2 years ago.
Old Apr 17, 2005 | 10:00 AM
glerma's Avatar
glerma
St. Jude Donor '05
You know... I forgot about that... My dad used to do that when I was a kid... it was the only time I ever saw him in front of a stove... I remember he seemed out of place...LOL
Old Apr 17, 2005 | 08:20 PM
mik's Avatar
mik
Default Thermostat
I think the stock themostat is 195 degrees. I'm changing mine tomorrow to a 180 degree. I'm glad to hear your operating temps dropped. That's what I'm after. The improvement is probably due to the lower temp stat.
Old Apr 18, 2005 | 07:06 AM
Atok's Avatar
Atok
Stock LT-1 is 180 degrees.
Old Apr 18, 2005 | 10:11 AM
KP Texan's Avatar
KP Texan
My vette got hot last summer due to a bad thermostat as well. I was thiking I was going to have to pull the radiator and clean it but a new thermostat did the trick.
To Cooling Issue Solved!
