What Rear End Gears?
Old Apr 16, 2005 | 10:25 PM
96redvettelt4's Avatar
96redvettelt4
Default What Rear End Gears?
Looking to upgrade my stock rear end. I know several people love the 4.10 in the 6 speed but I think its a little stronger than I want. Trying to find the middle of the road along with increasing on performance #s. I want to cover all angles-
1- What gear ratio offered between 3.54-4.10
2- Whats the best brands- which to stay away from
3- Best place to buy
4- What is a good total price to include install
5- Any good overlapping mods to do at same time
thanks for the help
Old Apr 16, 2005 | 11:11 PM
MYCoupe's Avatar
MYCoupe
I'll give you my input:
1. Sounds like 3.92s would work just fine for you.
2. I would try and get the Dana gears if possible.
3. I've heard good things about www.tomsdifferentials.com and www.randysringandpinion.com.
4. That really depends on your location. Around here they want $1000-1300 for the removal and install. You could save some money if you were to pull the differential yourself and just have the shop setup the gears for you.
5. The only thing I can think of is polyurethane bushings or a rear lowereing kit.
Good luck!
Old Apr 17, 2005 | 12:29 AM
GS348's Avatar
GS348
Default Go All the Way
I have just finished installing my 4.11's in my GS and I couldn't be happier. For the time being this is my daily driver and gas mileage hasn't suffered too much on the gear's account, it's more me mashing the pedal because I'm so happy with the improvement.
To be honest, once I am able to drive it less, I seriously think 4.30's will find a home in my dana. Many ZR1 owners are starting to do this, but I was trying to be somewhat conservative. SO, go ahead, get the 4.11's, you will be very, very happy
Old Apr 17, 2005 | 10:30 AM
STL94LT1's Avatar
STL94LT1
Default 4.10
Go with the 4.10/11's, you'll be amazed how drivable they are.
Old Apr 17, 2005 | 10:35 AM
JB666's Avatar
JB666
I have to agree with this. I got mine put in about a month ago.. 6th is actually a useable gear now!
55MPH is 1800RPMS, 70 is 2200, so the RPMS aren't bad at all!
Old Apr 17, 2005 | 10:44 AM
CFI-EFI's Avatar
CFI-EFI
The 4.11s will give you the same cruising rpms as an automatic with the optional 3.07 gears. No big deal and you get a 6th gear you can use.
5.) Universal joints.
RACE ON!!!
Old Apr 17, 2005 | 01:57 PM
95PoloVert's Avatar
95PoloVert
Active Streak: 90 Days
thanks for the help
1. I did 4.11's and love them. WAY more fun to drive...pulls hard out of the corners, and gas mileage only took about a 6% hit.
2. Richmonds make noise. Dana, US Gear, Precision are all good...if properly installed. I have US Gear, and my setup is as quiet as stock.
3. www.drivetrainspecialists.com - These guys have a ton of Corvette experience, great prices, and great customer service. Ask for Rich Perkins, and tell him you are a forum member for a discount. My 4.11's ran $216. Unless you are going to buy a 4-series carrier, you'll want a "thick" gear, which will mate with the stock 3-series.
4. I R&R'd the diff myself, and shipped it to DTS for the gear swap. The R&P ran $216...the install kit (bearings, shims, etc.) was about $100, and labor was $150...for a total of $456, plus shipping. Shipping via UPS ran about $50 each way...so the whole setup was $550-ish.
5. Poly bushings while you're in there. Unless you have a low mileage car, now is definitely the time to do U-Joints...it's a lot of work getting back in there!
-Scott
Old Apr 17, 2005 | 02:51 PM
96redvettelt4
Gentlemen thanks for the great feed back and wealth of knowledge. You all really have me relooking the 4.10/11s. But for all sakes does anyone have any input on 3.92s etc?
Old Apr 17, 2005 | 09:06 PM
96redvettelt4
tttt
Old Apr 19, 2005 | 09:20 PM
nearmiss's Avatar
nearmiss
I have 3.90's in my dana 44, LT4-6spd. I'm pretty happy with them,but the comments on the 4.10/11's are spot on. They would be fine for a daily driver. The only problem that I've had with the 3.90 is that it isn't a "standard" available GM option (AFAIK), so to program the speedometer, I've had to use a combination of standard ratios and false tire sizes to get the correct speed reading.
Old Apr 20, 2005 | 09:50 AM
Paul Campbell's Avatar
Paul Campbell
Another vote for the 4:10's here. This is the way the car should have come equiped from GM. It makes the car much nicer to drive and as others have said, gives you a useable 6th gear.
Old Apr 20, 2005 | 09:57 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
If I ever do a gear change it will be to a 3.73. Most of the road racers agree the 4.10s are too much shifting for a road course. They are excellent at the drags though. Depends on what you want.
Old Apr 20, 2005 | 10:00 AM
cv67's Avatar
cv67
St. Jude Donor '05
4.11's arent a pain to drive at all. I once tried going 3.73's with a 6 speed, tore them out 2 weeks later and went 4.11. You won't regret it!
If your'e going to do a gear change, do a gear change
Old Apr 20, 2005 | 10:42 AM
mos90's Avatar
mos90
are any of you 4.11 guys having to shift into 5th gear at the drags.. i like not having that extra shift.. i have stock 3.33 gears in and shift at 6500 rpms.
Old Apr 20, 2005 | 11:02 AM
LT4BUD's Avatar
LT4BUD
1) I have Dana 4.10's NOT 4.11's......41 tooth ring, 10 tooth pinion......
I think this is stronger than 4.11????????
2)With 4.10's and near stock LT4 tires....6300rpm is 115 mph in 4th.....so 6500 is between 118 & 119mph...so you can make a pretty good quess if you would need to shift or not......if you did & 1/4 mile is your thing then you need a different gear ratio
4.10's are a good choice for the LT4, both for performance and streetability......still don't know of anyone who regretted installing them
Old Apr 20, 2005 | 11:16 AM
mos90's Avatar
mos90
i would definatly need to shift to 5th with the 4.10's.. really dont want that. so a may be stuck with 3.73's..
Old Apr 20, 2005 | 11:37 AM
STL94LT1's Avatar
STL94LT1
Running 4.10's, I've crossed the traps at 117+mph and 63/6400 rpms, in fourth gear. I'm currently looking into updating my camshaft/valvetrain to get a couple hundred more, safe rpms.
To What Rear End Gears?
Old Apr 20, 2005 | 01:44 PM
96redvettelt4
For you guys that are running +115 mph what is your 1/4 times?
Old Apr 20, 2005 | 01:45 PM
DINO's Avatar
DINO
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
I went to Cruise-In V with Vetteweiser
GS daily driver , so sad ..... ....hope you can get a DD soon ...
Oh yeah I vote 4.10 ...if I had the cash that would be my choice hands down !
Old Apr 20, 2005 | 02:24 PM
STL94LT1's Avatar
STL94LT1
12.37 @115, and several 12.38's @116+, 117+ was in the 12.50 range
Most 60' times were around 1.90.
