Initial planning stages for next short block project.... ideas?
RACE ON!!!
Mike
I remember a few years back Hot Rod magazine built a big bore short stroke 350. Using a 3.25" stroke crank and 6.375" rods if my memory is correct. The cam was relatively mild and they used a set of AFR 195 heads running a final compression ratio of 11:1.With the rod combo HR thrased this engine on pump regular
and this engine made over 400+hp and tons of torq. The rods that they actually used were from a Ford 300 six cylinder engine. They had to be machined to fit the SBC crankshaft. The crank that was used was a 327 SBC steel crank. That same engine also got well over 20 MPG as well.
They attributed most of that to the ultra-long rod to stroke ratio:1.90:1. I keep eyeballing Speedomotive's kit for a very similar rotating assembly, 3.25 x 6.250" or 6.20" rod. Sounds like a great compromise in this time of gas prices, low octanes and the desire for power.
Yes, it stays indoors
Manley Sportmaster 6" rods and pistons(Those pistons are LIGHT)
Custom ground Comp SR 250/254 @ .050, .670/.660 lift, 110 L.S. adv. duration-I'dhave to look at my cam card. Around 284-288 or so.
Dart Conquest (early Pro-1)200. Flow just over 300-I can get the flow sheet if you like. The low/mid lift numbers were impressive also.
Team G thoroughly worked over plenum, lots of angle milling on heads/intake!!
0 deck, 10.5 comp.
1.6 Jesel SS series shaft rockers
All the usual BS-Screened/epoxied, ported oil pump/passages, studded bottom end, etc.
0 deck, 10.5 comp.
Wish I could have dyno'ed it. Ran out of $$. The person who did the heads and spec'd the cam is hoping for 560-570 @ the crank on pump gas.
You have a PM btw
Part #12-000-9, Grind # CS 4126S/4152S R 110.0
Cast gear valve lash .026 on int. and exh.
Gross valve lift (w/1.6 rocker).665 int, 648 exh.
at .050:int open@19 BTDC, close@ 51 ABDC
at .050:exh open 61 BBDC, close@ 13 ATDC
Installed @ 106 intake centerline
250/254 duration at .050, 110 lobe center.. (ramps are slightly inverted)
Springs 200#and #500, installed height, can't remember for the life of me. More to come
You have a PM btw
Ron
ABSOLUTELY!
Based on the constraints you listed - driveability, etc., - 1.0 to 1.1 HP per cubic inch (NA) should be about what you can expect.
If you do the math, you'll see you'll end up with much more power by starting off with more displacement and the engine won't have to work as hard.
Jake
ABSOLUTELY!
Jake
So now what I'll get are posts from guys saying "I've been running blah, blah, blah . . ." or "I know so and so who's been running blah, blah, blah". . ." or if you build 'em blah, blah, blah . . ." Fact remains, sooner or later they blow up. End of story.
If I got hit by ligntening and had a mind fart then decided to one day build one, I'd be thinking big, strong and heavy in my parts selection.
Big springs, strongest rods/bolts/pistons my bank account could stand; Bow-Tie block with 4 bolt mains on all five, not just the center three; forged pistons with really thick decks, lots of piston to wall and heavy walled pins; 5/16ths rings with huge end gaps; "O" ringed block deck, internally balanced top-of-the-line forged crank with full counter-weights and NOT lightened, Jesel shaft rocker setup, extra cooling capacity, etc., etc.
I'd let torque do the work and go no higher than five grand in Rs.
Steel wherever I could put it (like in my rocker arm selection), low compression, timing and RPMs.
Then I'd have to start signing checks for driveline stuff; the trans won't live, the half shafts and drive shaft will soon be history along with the ring and pinion. Torque's a parts killer and what it doesn't kill right away, a momentary lean A/F ratio will take care of.
To pump up the power with an adder, you've got to think STRONG everywhere including the driveline; not light; that adds up to lots of $$$ too.
And no, I'm sure he didn't mean you could get 4.125 bore out of a 350 block; you'd be pushing it to go .060. His point, I'm pretty sure, is the same as mine; that it's much easier to get higher power when you start off with lots of cubes.
If I was in the market for lots of torque and HP, I'd do whatever I had to and drop a 540 BB in mine. I'd still have the drive line woes, but I wouldn't worry that the engine would gernade on me.
Just my thoughts.
.Jake
