Crank end play
Old Apr 19, 2005 | 10:56 PM
Pete K's Avatar
Pete K
Default Crank end play
Talk about a bad day. Thrilled with the new found power and drivability of my new 406 and the crank loses it's thrust. .004 end play turned into .016 in less than 100 miles. This is right after my wife throws away my custom programmed chip. Didn't even get a chance to pop it in the ecm before it vanished.
Old Apr 20, 2005 | 08:16 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Old Apr 20, 2005 | 08:34 AM
96dblblack's Avatar
96dblblack
that really sucks.
Old Apr 20, 2005 | 10:07 AM
cv67's Avatar
cv67
St. Jude Donor '05
I'd be just a bit irate...Any idea what caused the excess play?
Old Apr 20, 2005 | 10:22 AM
LD85's Avatar
LD85
I wonder how that number grew, I always thought the end play "is what it is". I set mine last Saturday and it was at .006"
Old Apr 20, 2005 | 10:26 AM
Red Tornado's Avatar
Red Tornado
Pete, I can't help with dtermining what caused excessive end play, but I can drive up there and help you look for the chip.
Old Apr 20, 2005 | 11:21 AM
jburnett's Avatar
jburnett
There goes the thrust bearing... #5... See ya... That sucks, dude; time to pull her out.
-Jeb
Old Apr 20, 2005 | 11:54 AM
chucks88's Avatar
chucks88
That is reason #561 why I never considered getting one of those wife things.
Old Apr 20, 2005 | 01:48 PM
Pete K's Avatar
Pete K
-Jeb
Yep. As soon as I saw the dial indicator sweep across the face of the dial, I knew exactly what it was. Sux bad. I am not sure if the bearing is bad or a damaged thrust surface on the crank. Either way, out she comes.
Old Apr 20, 2005 | 01:49 PM
Pete K's Avatar
Pete K
Learn from my mistakes. NEVER do it.
Old Apr 20, 2005 | 01:51 PM
Pete K's Avatar
Pete K
Thanks Brad, It is not in the house or garage anymore. She pitched it in the garbage. Sometimes I thing she may be
Old Apr 20, 2005 | 01:53 PM
Pete K's Avatar
Pete K
That usually is the case. Thrust changes little over the life of the motor. My case is unusual, to say the least.
Old Apr 20, 2005 | 09:45 PM
Red Tornado
Pete, what caused the thrust bearing to go like that?
Old Apr 21, 2005 | 07:36 AM
Pete K's Avatar
Pete K
Brad, Considering that I used a know good torque converter, flexplate and balancer, that leaves the crank and bearing as the only 2 possibilities. The endplay checked out fine when assembled, so that leaves me suspecting the bearing. The odds of a bearing being defective are very slim. However, the odds of a new set of hydraulic lifters not having springs in them is a 1 in a million shot as well. I would avoid standing next to me if we are outdoors and you hear thunder.
Old Apr 21, 2005 | 08:39 AM
Red Tornado
Pete, thanks for the education. Damn this sux. Well as you always say, time & money fixes all this nonsense.....how true (and terribly annoying).
Thunder? THAT would be your 406, idling
Old Apr 21, 2005 | 09:37 AM
cv67's Avatar
cv67
St. Jude Donor '05
Well Pete, an least you are able to find some humor in it! Let us know the lowdown after you pull the pan...
Old Apr 21, 2005 | 03:52 PM
Pete K's Avatar
Pete K
True. I am actually more upset that my prom was tossed than the motor issues. Clearly it should be the other way around. As Brad said, time and money will fix it. This is not the first time I have had motor issues. If it were easy, everyone would have a 10 second car. You gotta earn it I guess. Gonna take a few days to cool off and then have at it. I got a new digital camera for christmas. If I see anything cool after I pull it apart I will try to post pics of it.
Old Apr 21, 2005 | 09:48 PM
ralph's Avatar
ralph
May i ask, what made you recheck your end play? I set mine when i built the engine and never looked back. Should this be checked periodically or did you have some symptoms.
Old Apr 21, 2005 | 11:04 PM
Pete K's Avatar
Pete K
Ralph,
I was sure to install a new hi torque mini starter as a precaution due to the extra heat I expected from the new 406. After my first test ride I heard a scraping noise pulling in the garage. I found that the tip of the bendix was just nicking the rotating flexplate. With no foward or rearward adjustment, I remover the starter and used a dremel to "profile" the end of the bendix. I had about .025 between the 2. After 100 miles of normal driving I heard the grinding noise again. When I saw no air gap and found the starter was bolted tight, I knew to check crank endplay. The prybar made it feel like .050 but the dial indicator said about .015. My notes say I had .004 in the 3 spots that I checked during assembly. To lose the thrust in a new motor is odd, to say the least. I will figure it out when I get it apart. For reference purposes, the old 383 removed from the car had .003 new and .0035 when pulled. The .0005 wear is typical. I am still in disbelief.
To Crank end play
