Air intake options
Old Apr 20, 2005 | 03:02 PM
DESPERADO's Avatar
DESPERADO
Default Air intake options
One of the clip-nut flanges on my air filter lower housing is broken, so I'm looking at alternative air intake solutions to the stock set-up.
What I've seen out there is the Vortex Rammer, Forced Air Induction (using licience plate facia), and the SLP system.
I was also thinking about the option of using functioning NACA scoops in the hood.
I do not like the look of the Forced Air Induction kit.
I would like your opinion on the other three methods for increasing your intake air flow. What looks good, and works great? What other options are there, other than the ultimate in fun... blowers & superchargers?
Old Apr 20, 2005 | 05:46 PM
Lichen's Avatar
Lichen
I know a lot of forum members are going to disagree with me, but I have the Vortex and I really like it. It looks good and I have had no problem with warpage (knock on wood). At slower speeds, I doubt that it does much more good than a K&N with an open lid, but at higher speeds, I do believe that it makes a difference, allowing more air into the TB. Plus it make this giant sucking sound (I hope it's not the sound of over $200 being sucked out of my wallet.
Old Apr 20, 2005 | 10:06 PM
92Roadster's Avatar
92Roadster
Old Apr 20, 2005 | 10:20 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
FYI, TPIS has the Air Force ram air system.
I run the SLP ram air and it does a decent job. It gave me about 5chp over the cut lid with K&N. BTW this system somes with a stock size K&N filter. It requires only cutting a small rectalgle from the front of the stock radiator shroud, through which passes the air scoop.
Old Apr 20, 2005 | 10:34 PM
vader86's Avatar
vader86
None of them gives the advertised gains, but if youre looking for a replacement, I'd go with the Tpis or SLP part.
Old Apr 21, 2005 | 01:28 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
The SLP is worth every penny IMO. (well, on sale at least). And I don't say that about many of these aftermarket things.
Old Apr 21, 2005 | 02:12 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Do your own tests on air systems and you decide.
Try removing the front of the air cleaner infront of the maf.
Notice how the engine will stall or stumble.
Use the fan from the raidator when it is on and move the maf infront of the fan and car will stall.
Now move the maf away from the fan and see what happends.
Will the engine realy make more HP or will it just suck money out of your pocket?
I have an L98 and ran a 12.50 with the air cleaner removed.
The air cleaner installed stock no cut lid 11.95 run's back to back .
Yes I am using a 150 shot of nitrous.
No other changes but removing the air filter.
Slower with air cleaner removed.
ON my LT1 different storie it picks up 1/2 second with air cleaner removed.
Old Apr 21, 2005 | 09:39 AM
DESPERADO's Avatar
DESPERADO
The air cleaner installed stock no cut lid 11.95 run's back to back.
Air flow from a fan is not ideal, it is hot and very turbulent. When you did this and found the engine had difficultly it was probably because you were causing a decrease in air flow. Remember the engine is a big air pump, the more you can get IN and back OUT the more power you'll get. This air has to flow well (ie port and polished heads).
The idea of these kits is to increase access to cool clean (non-turbulent) air flow. An air filter will also help in straightening the flow.
Old Apr 21, 2005 | 09:40 AM
DESPERADO's Avatar
DESPERADO
Looks like SLP is winning...
No one has tried NACA scoops?
Old Apr 22, 2005 | 01:19 AM
REDC4CORVETTE
I have the SLP unit, the claw on my 94 with the through the license plate induction, and that does make a diff.
The LT1 even if you blow into the front of the car with an air hose the RPM picks up.
But I also have the air foil.
Old Apr 22, 2005 | 01:48 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
I went with the 'hole in the bumper' for cold air setup. Cost nothing, and I just put the front plate ( or cover ) on when I'm done.
The other option is just cut a hole in the bottom of your filter housing, a corresponding hole in the radiator duct, and sandwich a filter between the two.
Old Aug 3, 2005 | 07:05 PM
88BlackZ-51's Avatar
88BlackZ-51
anyone else remove the air cleaner at the track? is this safe. you say .50 gain? that is alot.
Old Aug 3, 2005 | 07:40 PM
MacVette86's Avatar
MacVette86
I installed the SLP CAI on my 86 and it works great. It pulls the air from under the front bumper. Same place where the air to cool the radiator comes from.
Old Aug 3, 2005 | 08:10 PM
FlyboyZR1's Avatar
FlyboyZR1
Love my SLP, sold the TPIS intake for it.
Old Aug 3, 2005 | 08:34 PM
vader86's Avatar
vader86
The only caveat being that some of this air is now being sucked into your tract, instead of being used to cool the radiator.
People with cooling problems should be mindful of this, a 10 degree average gain would not be unexpected.
Old Aug 3, 2005 | 10:22 PM
CentralCoaster
Lemme backtrack on the props I gave to SLP. It's not great quality, hard to get a good seal on the filter as the flimsy plastic housing warps a little, but I'd say it's a good buy. As for radiator air, I was never deficient there, but the bigmouth more than makes up for it, and helps the ram air somewhat.
I didn't like the opening into the SLP, so I added a turning vane in the middle, which should bump the airflow up by about 40% (on paper at least).
To Air intake options
