really quick dumb horn Q
Old Apr 21, 2005 | 01:27 PM
jeremy carl's Avatar
jeremy carl
Default really quick dumb horn Q
where is the fuse for the horn on an '86 C4?
and how many horns are there supposed to be in the car?
Old Apr 21, 2005 | 02:02 PM
Square's Avatar
Square
I don't know where the fuse is off hand, but there are supposed to be 2 horns on the car. There should be one bolted to the frame rail under each headlight. I replaced both of mine last year. I couldn't find OEM stle replacements, so I just used the generic ones that the corvette supply houses sell. They work fine, they just look like aftermarket.
Old Apr 21, 2005 | 02:38 PM
mikey whipreck's Avatar
mikey whipreck
The fuse is behind the DIC cluster (behind your idiot lights). The horn relay is there also.
At least that's where it is for my '85.
Old Apr 21, 2005 | 02:42 PM
jeremy carl
OK Im new to this, where is the DIC cluster and what are the idiot lights?
Thanks for tour help.
Old Apr 21, 2005 | 02:44 PM
jeremy carl
Sorry revise that I worked it out. If the relay clicks when I press the horn could the fuse still be blown?
Old Apr 21, 2005 | 03:22 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/agent86/Horn%20Electrical.pdf
Old Apr 22, 2005 | 12:50 AM
mikey whipreck
If the relay clicks- that should mean that the horn contact is good, the fuse is good, and the relay is good. All that is left is your horns or the wiring on them.
In my case One horn was dead when I bought the car, and I didn't realize it. After a while, the other horn died. I couldn't believe both would die at the same time, but actually I only lost one, since the other was already shot.
lol, sorry:
for future reference, the DIC (Driver Info Center), is the black window in the middle of your dash where the lights such as "Hatch Ajar" "Check Engine" "Park Brake" etc. are located...
and 'idiot lights' are just a term for those lights.
Old Apr 22, 2005 | 08:28 AM
prodadiv's Avatar
prodadiv
check your ground for the button. There is a connection within the horn button that can loose ground. I had this problem a couple of weeks ago on a 1990 and fixed it by cleaning the connection.
Old Apr 22, 2005 | 12:12 PM
jeremy carl
Thanks fr all your help, got 2 new horns for it today, couldnt believe they would die at the same time.
Cheers
Old Apr 22, 2005 | 10:15 PM
mikey whipreck
Cheers
did that fix it?
Old Apr 23, 2005 | 03:03 PM
jeremy carl
did that fix it?
yea that fixed it! thanks, there bloody loud arent they. Just one of those jobs ya put off till someone almost backs in to ya and ya dont have a horn to honk.
To really quick dumb horn Q
