Waxing Woes
Old Apr 21, 2005 | 08:17 PM
The13Bats's Avatar
The13Bats
Default Waxing Woes
I have a black car with good paint,
I set out to wax it so I used meguires, I stared with the paint cleaner-wax and a fair amount of funk came off then I used the polish, then sealer carnuba wax, well I apply the wax by hand and then let it dry to a haze and using a clean terry towel go to wipe if off by hand and it leaves "wet" looking swirls, not the scratch swirls you see with electric buffing but a wet looking swirl that almost looks like you hit it with an armor all type product , these swirls are very hard to buff off,
What am I doing wrong???
Thanks,
P.
Old Apr 21, 2005 | 08:54 PM
6spd's Avatar
6spd
i have a white vette and what i did is i clay bared the whole car then i used meguiers 80 speed glaze then i used there show car #7 polish then i used the nxt wax holy sh-t what a diffrence. i did use a porter cable machine. but you can do it by hand.
Old Apr 21, 2005 | 09:39 PM
odysseysteve's Avatar
odysseysteve
While I don't have an answer for ya, I know the guys in Forums/General Corvette/Car Care Products most likely will.
Old Apr 21, 2005 | 10:45 PM
jjgkdg's Avatar
jjgkdg
Default wax swirls
Just wash the car again and dry like you normally would. I had the same problem and asked the guys in the detail shop of the dealership I work at. Washing afterward also gets all the wax powder off.
Old Apr 21, 2005 | 10:55 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
Mine is black also...Meguire's NXT solved all the problems...I also hit it with the Booster wax in between and Quick Detailer after every wash....clay bar once a year as well... all done by hand with no problemo's...
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Add some cornstarch to your waxpad.
Old Apr 21, 2005 | 11:04 PM
ls5454's Avatar
ls5454
My experience: 4 black sportscars; very picky about cleaning
Points to remember:
1. Everything done in shade can be fixed in shade.
2. Swirls mean you let it dry too long/used too dry a wipe cloth.
Start with car that has not been in sun yet that day. Clean with water, then wax. Clean and wax in shade. Do not try to do a portion too large on your car. Do not let it dry too long on your car. Use a barely damp cloth to wipe off wax. If swirls are visible after wiping, use more wet wax on area and wipe immediately.
Old Apr 29, 2005 | 10:09 AM
rufneck's Avatar
rufneck
Default zYMOL
Use Zymol @ 3mo Stuff Is Really Great
Old Apr 29, 2005 | 10:30 AM
gbody5's Avatar
gbody5
Seeing that you are in Florida, I suspect the high humidity is affecting the 'drying' time. I used Meguires for years, good wax that lasts, but now I'm stuck on Zaino products, especially on Black, best shine I ever had and absolutely zero swirls.
http://www.zainostore.com/Merchant2/merchant.mvc
See my website, gallery of my black car for example.
Old Apr 29, 2005 | 10:46 AM
cv67's Avatar
cv67
St. Jude Donor '05
I've always sworn by Meguairs products for years. I tried the cleaner/wax too on the vette and wound up with some fine swirls like you said. I found the Zymol wax at Pep Boys, tried it and they are all gone! Car looks like it has 10 coats of clear on it.
Old Apr 29, 2005 | 12:38 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Also, when you are buffing it out, use fore-aft motion, not circular.
Old Apr 29, 2005 | 01:33 PM
F1Fan's Avatar
F1Fan
Virtually every thing will scratch your finish IMO. Use only super soft 100% American (not pakistani etc) terry cloth towels. Even the bindings on the edges of towels will scratch. Black is just about my favorite color, but you gotta earn that finish when you own a black car. Invest in a couple good quality bath towels for you car.
fwiw, I used Zaino quite a bit over the last few years, and got tired of the expense and hassle of ordering it so I switched to Mequires and was dissapointed with the results, went back to the Zaino and will stick with it. Z5 is good stuff for swirls.
Old Apr 29, 2005 | 01:52 PM
Ivory90's Avatar
Ivory90
Default Tech Wax goes on easy comes of easier...
leaves no swirls, leaves a butter soft finish. I also use the speed detailer with microfiber towels...no scratch from this! My paint is only 6 months old so I've yet to clay bar it but I'll be doing that every 6 months once I get up to about 6 layers of shinola!
The NXT really does bring out the white diamonds in my paint!
I let a buddy who's got a red SL500 AMG use the tech wax and the difference is unbelieveable. The best part about the new NXT wax product is it's a single stage process...no need to put a prep layer under the wax or a polish layer on top.
Zaino is good stuff, but NXT tech wax is soooo easy.
Old Apr 29, 2005 | 04:20 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
I think you'll find your answers in that post.
By the way, cornstarch works well, but only if you use it when you are taking the wax OFF!
Larry
code5coupe
Old Apr 30, 2005 | 05:22 PM
DRE69L46's Avatar
DRE69L46
Default Zaino!
Zaino is a lot of work and expensive, but the results are amazing! Well worth the $ and effort.
To Waxing Woes
