Replacing engine, should I lay in headers first??
Old Apr 23, 2005 | 12:48 PM
Strike3's Avatar
Strike3
Default Replacing engine, should I lay in headers first??
I'm about to the point where I drop the engine back into the car. I am installing TPiS headers and was wondering weather I should set the headers in place and perhaps tie them to the inside fender wells, before setting the engine in. Or is it not worth the trouble?
Is there any other time/effort saving tips on things-to-do prior to installing the engine??
Thanks guys!!
Old Apr 23, 2005 | 11:52 PM
bogus's Avatar
bogus
no.
There is sooo little room as it is, once the engine is in, before you do the accessories, then fit them in.
Old Apr 24, 2005 | 09:34 AM
Strike3's Avatar
Strike3
Thanks Bogus! Makes since.
Old Apr 25, 2005 | 05:53 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
There's no reason to. I've either test fitted or installed four brands of headers on my C4. They all slipped up into place very easily. You will need to leave the plugs and the temp. gauge sending unit out until they are in place. The four brands were Stainless Works, Hedmans, EMs and DRMs.
Old Apr 25, 2005 | 06:19 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
i had my front end off the ground and the headers slipped right up. just make sure you have ground clearance to shove them up.
To Replacing engine, should I lay in headers first??
