Plug recommendations
Old Apr 23, 2005 | 03:11 PM
jeremy carl's Avatar
jeremy carl
Default Plug recommendations
what are the recommendations for a good spark plug to use on an '86? So far the engine is standard.
Old Apr 23, 2005 | 03:39 PM
sniperdiver37's Avatar
sniperdiver37
a plug is a plug is a plug. They are all about the same and do the same unless you are throwing more spark to them ie. MSD, accel , High Volt coils ect. What your paying for in OTC plugs is the life of them. If you tune your car one a year just go with a good brand name champ,NGK, ect. if you drive it alot and don't like to wrench go with a high milage plug. If you have High Volt mods already then you should already know the answer to your question
Old Apr 23, 2005 | 06:35 PM
rws.1's Avatar
rws.1
A lot like The standard AC Delco Rapidfire,
I prefer Bosch Platinum +4.
vader86's Avatar
vader86
Rapidfires
Old Apr 23, 2005 | 08:40 PM
stevec4's Avatar
stevec4
Just changed mine for Platinum+4 and the idle improved dramatically (although I also replaced distributor cap, rotor and leads).
I like their design which opens up the flame front similar to those people that cut back the center electrode.
Old Apr 23, 2005 | 11:57 PM
vettefun's Avatar
vettefun
AC Rapidfires worked great for me!
Old Apr 25, 2005 | 02:20 PM
Vetterin's Avatar
Vetterin
I've tried platinums on my 85 but it seems to me as though the stock AC copper cores are just as good.
To Plug recommendations
